just replaced tie rods and......
Old Feb 27, 2012 | 04:21 PM
j4s0n1337's Avatar
Default just replaced tie rods and......
i just replaced my tie rods (inner and outer) on my 95 sedan and my steering wheel was off to the left a little bit and now it's straight. Does that mean i have to adjust the tie rods a little more or could the tie rods be why my wheel wasn't aligned?
Old Feb 27, 2012 | 04:33 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: just replaced tie rods and......
You didn't count the number of times you turned/screwed it off/on correctly. Adjusting the tie rod does affect your steering wheel center. I would suggest getting your car aligned.
Old Feb 27, 2012 | 04:48 PM
j4s0n1337's Avatar
I counted, the outer rod was a bit longer so I compensated for that. Idk what the hell is going on with this car but I'm about on more problem away from selling it, hahaha
Old Feb 27, 2012 | 06:53 PM
seanbev24's Avatar
Go get it aligned properly. Problem solved.
/Thread.
Old Feb 27, 2012 | 07:09 PM
19Accord97's Avatar
You should ALWAYS get your vehicle aligned when doing suspension work.
Old Feb 27, 2012 | 08:04 PM
dglassmyer's Avatar
I just do the kite string technique for adjusting toe.
At least it would get you safely in for a proper alignment.
http://www.youtube.com/watch?v=W8qFjAB67vk
Old Feb 27, 2012 | 09:15 PM
j4s0n1337's Avatar
I'll have to try that string technique in the morning, would this work even though my steering wheel wasn't aligned to begin with? It was always crooked whenever I would drive straight.
Old Feb 28, 2012 | 03:35 AM
dglassmyer's Avatar
Yes, just secure the steering wheel level when you set your toe.
Old Feb 28, 2012 | 05:20 PM
scab's Avatar
love the video, now i know how simple it is.
Old Feb 28, 2012 | 06:00 PM
j4s0n1337's Avatar
Ohhhhhhhhhhhhhh, okay, I get it now!
sorry guys, my n00b was showing
Old Feb 28, 2012 | 06:15 PM
dglassmyer's Avatar
Welcome Scab, good to see another user from the DFW area on here, I live in Denton.
To the OP, the most important thing to watch for when setting toe in this manner is that your tires are able to "slide" on the tiles.
You want to make the point they rest on the tiles as friction free as possible, I even put down lithium grease to help them move easier.
What you want to be able to see is the small adjustments made on the tie rods reflected in the wheels position in relation to the string.
If you notice your making several turns of the tie rod, and the wheel isn't moving, its likely because your tires have too much traction.
I have even considered making myself some homemade alignment plates, the kind you see on alignment racks at shops which are perfectly friction free.
Good luck.
bark3rk20
Suspension & Brakes
Jun 30, 2011 05:32 PM
sleeptime
Mar 17, 2011 07:07 PM
StupidSlowRSX
Jun 13, 2007 05:49 AM
b16ferio
Mar 27, 2004 03:42 PM
