2000 gsr turbo build
Old Feb 26, 2012 | 12:31 PM
phaphon's Avatar
Default 2000 gsr turbo build
hey whats up i picked this car up around dec 2010. Picked it up for a good price off a friend.It had a spun rod bearing.So i fixed it, made a mistake rebuilt it for my dd so everything went back to oem.I previously had a boosted ls so of course i missed the power.After about 5000 miles of hard miles on the motor i boosted it. Bought a s300 hondata and put it together took it to get tune.Then boom goes the sleeves. so now im at it again drop the block off to mike at laskey racing. There it got sleeved, also picked up some cp pistons and eagle rods along with mircro polishing, and balancing the crank.This time around i took it to a local machine shop to assemble the bottom end.Then i put the rest of the motor together put it in.This time on the dyno i spin a rod bearing.So as of now the motor is back at laskey racing for them to assemble it. This time around i will be towing it to so cal to get tuned there.
parts list
benson sleeved 84 mm gsr
cp 10:1 pistons
eagle rods
acl race bearings
balanced rotating assemble
head
gsr head
super tech springs/retainer
ferrea 6000 series vavles
victor x manifold
750 rc injectors
turbo kit
turbonetics super v turbo .48 trim
tial waste gate
cast iron log manifold
ebay bov(yes i know i willing be looking for a quality bov once i get everything together)
threadstone ic
ems
hondata s300
boost by gear
i been through alot with this car and just wanted to share with everyone else so enjoy
Old Feb 26, 2012 | 12:34 PM
phaphon's Avatar
Default Re: 2000 gsr turbo build
I'm trying to figure out how to post pictures at the momment. They will be up in a little.
Old Feb 26, 2012 | 12:40 PM
phaphon's Avatar
when i first cracked the sleeves
Old Feb 26, 2012 | 12:43 PM
phaphon's Avatar
pictures of the car
enjoy i will be updating as i go along this time
Old Feb 27, 2012 | 05:52 PM
TypeRMOBBiN209's Avatar
in for this
Old Feb 27, 2012 | 06:42 PM
boofunit's Avatar
how many psi were you running when you cracked the sleeve?
Old Feb 27, 2012 | 08:55 PM
phaphon's Avatar
I don't know tuner set my boost cut at 11 psi when a stock map sensor didn't read that high
Old Feb 27, 2012 | 09:51 PM
racebum's Avatar
boost cut doesn't mean a lot, what pressure was the wastegate blowing off? that's serious detonation you had going on
Old Feb 27, 2012 | 10:01 PM
ek9.5's Avatar
sickk keep up the good work
Old Feb 28, 2012 | 07:39 AM
phaphon's Avatar
the spring is a .9 spring and i was making about 240 wht and about 200 whp at about 5000 rpm let me look for the dyno sheet i think it was cuase of boost creep.The tuner said my waste gate vacuum line was connected wrong so i offered to fix it and he said its ok its not creeping so i thought it was ok and took his word for it
phaphon's Avatar
thanks
Old Feb 28, 2012 | 07:48 AM
phaphon's Avatar
Old Feb 28, 2012 | 07:56 AM
kyden's Avatar
what the hell is going on with your air fuel ratios?
Old Feb 28, 2012 | 08:31 AM
phaphon's Avatar
idk i knew it was bad when i saw the sheet but i didnt know how bad it was till i let my brother in law look at it
thats also why im paying the money to tow it to socal this time
Old Feb 28, 2012 | 06:31 PM
HeLLa iLL2ndGen's Avatar
Here's a couple pics for you broo
Old Feb 28, 2012 | 06:56 PM
gpr's Avatar
gpr
lots of potential there. GL on the build
Old Feb 28, 2012 | 07:04 PM
phaphon's Avatar
Thanks and yeah I sure do got a lot more to do
Old Feb 28, 2012 | 07:08 PM
phaphon's Avatar
thanks rick
Old Mar 2, 2012 | 03:30 PM
BignevadaBoB's Avatar
Wow. Curious as to who "tuned" your car...
Old Mar 2, 2012 | 04:47 PM
phaphon's Avatar
new updates got my block back from laskey have not unwrap everything.Will start putting it all back together on sunday then hopefully i get to drop the motor in on monday.
Old Mar 2, 2012 | 05:05 PM
phaphon's Avatar
Old Mar 2, 2012 | 05:38 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
damn that is some story you have there. i hope everything goes well this time around. but i agree about that fuel curve is almost not even there
Old Mar 9, 2012 | 12:04 PM
phaphon's Avatar
got the block put together and its in the car.hopefully will get it started this weekend
Old Mar 20, 2012 | 06:15 PM
phaphon's Avatar
Here's an update tuned it yesterday 241 178 at dnr with ny stock exhust
Old Mar 21, 2012 | 10:09 AM
psidriven's Avatar
congrats. how much boost was that at? hope the a/r is better this time.
