b16 intake upgrade vtec problem
I put a skunk pro series manifold and blox 68mm throttle body on my B16a2, and now i lost power in vtech, like 2nd is topping out at 51 veruses previous 64... it wont build power past 7100.???
It's confusing the way you explain the issue, is it hitting redline early or you're just saying ther power band has moved around?
the problems confusing.. i guess the power band has moved around. Before the upgrades i built power and shifted at 8000, now it falls on its face a 7200, it will go past that but slower than *****. seems slower throughout entire rpm range, but havent been to track to compare times
Your stock ECU doesn't know how to compensate for the change in air/fuel so it does what it can. If you want to get any benefit out of these items you need to get tuned or at the very least a basemap for your setup.
This is what happens when you buy into the hype and start slapping on parts thinking that you gain horsepower with them. Skunk2's marketing department needs an award.
I just got my hands on an ITR IM and TB but I won't be installing it until I get my itr cams/springs/retainers. For the simple reason that I don't want to have happen what's happening to the OP. If there's only 1 single thing I've learned from honda-tech it's GET A TUNE WHEN YOU GET PERFORMANCE PARTS!
Cool Cool Island Breezes. BOY-EE
Single stage VTECH? Damn.
The engine shouldn't be falling flat on it's face just because of the skunk2 manifold...especially at high RPM. I used a ITR manifold on my B16A and it just made more power up top. The way you worded the issue is confusing.
You're saying that around 7100RPM or so, the motor just stops making power? That shouldn't happen with a throttle body and manifold install...even with the stock ECU.
You might have done something wrong. Are you sure all the sensors are plugged in properly?
You could try a fuel pressure regulator to richen the mix up a little. Or use like a stock ITR ECU or something.
I believe all sensors are plugged in and functional including knock... I have no engine lights.. I Do also have an AEM fuel rail with B&M Fuel Regulator, did not seem to help much. seems that no matter how i ajusted it all it changed is weither it bogged on low end or bogged highend. I have since reinstalled factory tb, has made a lil better, not much though
ummm not sure on brands notihing special before throttle body, just a tube and knockoff k&N cone, they were on the dseries that came out of the car. i have stock tb on it right now, had blox tb and skunkz manifold, but removed blox for troubleshooting.. Would a intake leak on the manifold sound likely. im unsure of a torque pattern on the manifold, maybe? ... its reving slightly at idle..
ill get some pics up shortly, tps is set .5 closed and 4.7 wide open. I guess the next step is to replace manifold gasket and retorque manifold.. is a crisscross pattern acceptable.
Im sorry im not sure how i have given any new information that is that helpfuil... grumblemarc
just so you realize the p30 IM is one of the best intakes out there. especially for your engine.
so go back to stock. do you have any supporting mods for this waste of an idea?
Is VTEC turning on? I'm sure you can hear whether it is or isn't. If VTEC was inoperational, the power would suffer up top.
If the car revs up a bit at idle, you might have a vacuum leak...but it would have to be a pretty damn big vacuum leak to affect anything at WOT on a speed density car. Think of the throttle body as a 65mm vacuum leak at WOT.
