OBD0 engine into OBD2 chassis HELP!!!
Okay so I killed my D15b7 swap and now Im trying to swap in a big bad DOHC. I found myself a obd0 b18a1 swap (out of 90 integra) and the only parts I have for the swap so far:
New OBD2a engine harness
B series mounts (minus rear mount bracket)
what else will I need to swap this obd0 motor into my obd2 chassis? Axles? Mounts? Wiring? etc.
all help would be greatly appreciated!!!!
Just use your wiring harness, you need a hydro transmission, swap mounts, linkage, a 98 integra ls ecu, use obd2 injectors, you need a t bracket off a 99-00 si, a obd2 altranator, integra axles, am I missing anything,
i am currently doing the same. except i just changed the altenator and dizzy plugs to obd0 and then changed the injector with my single cam ones to run obd2a injectors.
but no crank :\
but no crank :\
