1 wire o2 sensor @ the collector?
Old Feb 25, 2012 | 10:29 AM
661rex89si's Avatar
Default 1 wire o2 sensor @ the collector?
running a y8 header but the o2 bung is at the collector. im still obdo so im wondering before i go spend money to have a o2 bung placed at the runner if it will be fine at the collector. will it cause issues since its a non heated type sensor.
Old Feb 25, 2012 | 11:48 AM
KINGVEM^^ED6's Avatar
Default Re: 1 wire o2 sensor @ the collector?
Its gonna give u cel for o2 im having the same issue right now
It will come on when going down hill
Or when motors at low rpms
Old Feb 25, 2012 | 11:49 AM
Also how much.are you thinking its.gonna.cost
Old Feb 25, 2012 | 08:49 PM
90civic-ZC's Avatar
661rex89si.....awesome profile pic. And KingVem I assume you're running OBD 0 yourself. I have a DC header I've been waiting to install and the o2 is in the middle of the downpipe right before the cat. You're saying I would throw the o2 code because of it's position? I've heard of this issue but have had no personal experience and havent read up on it....also have been worried this would be the case.
Old Feb 25, 2012 | 09:12 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
With a single wire O2 sensor (non-heated) it must be within around ~12" or closer (non-scientific) from the cylinder head to function properly. It relies on the exhaust gases to heat itself to get a proper reading. The downside is typically only one or two cylinders can be monitored. When a 4 wire O2 sensor (or 3 wire for that matter - (heated)) is used it can be placed further downstream to get a more accurate reading of the overall Air Fuel Ratio from all the cylinders on that bank. So you can see which is preferred... I have posted many times about how to wire up either or in other threads to work while still running OBD-0...
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/4-wire-o2-obd0-3027163/
Actually, pretty much all of your questions should be answered in there. If you have more, I can always help you further.
Old Feb 25, 2012 | 09:19 PM
90civic-ZC's Avatar
Thanks man......that is exactly the info and details I've always wanted to learn. I knew the o2 had to be close but never knew why and how far was TOO far. And thanks for the link, I'm gonna check it out now.
Old Feb 25, 2012 | 09:51 PM
90civic-ZC's Avatar
https://honda-tech.com/forums/showthread.php?t=3027163
That was a FAN-****IN'-TASTIC write up....."Nevereversatisfied".....I put it in my favorites on my computer. Definitely gonna go that route before I install my headers and full exhaust.
661rex89si
Jan 31, 2009 06:10 AM
CXtypeR
Mar 13, 2007 07:26 AM
mugenhatch92
Aug 21, 2004 09:38 AM
quik89
Jul 24, 2004 03:40 PM
Aphrodavid
Dec 15, 2002 04:50 PM
