Fuel Injectors going bad?
Old Feb 25, 2012 | 07:14 AM
DJ Strike It Up's Avatar
Default Fuel Injectors going bad?
Hey guys, I'm hoping someone can give me some guidance on what I need to fix on my Accord. I have a 1993 Honda Accord LX.
Here's the issue, when I start up the car, she sounds like a loud lawn mower. When you drive it, it still sounds loud, shakes a bit and you can smell an odor of gas. But the car temperature is normal, the rpms are usually normal, but she idles a little rough. Sometimes she has even turned off, but she will start up right away with no problem. The funny thing is that after you drive her for a few minutes, she starts to run normal. She stops being loud like a lawn mower, she idles smoothly and she runs like a dream.
So what gives? Is one of the injectors going bad? Is it the fuel pump going bad? Any help and advice is greatly appreciated.
Thanks!
-Strike
Old Feb 25, 2012 | 04:59 PM
v4lu3s's Avatar
RTFM
Default Re: Fuel Injectors going bad?
when was the last valve adjustment done?
Old Feb 27, 2012 | 07:33 AM
Deatschwerks's Avatar
When you first start the car. Try disconnecting each of the spark plug wires. If you pull one and it doesn't change, you know you have a problem with that cylinder.
As far as the injectors go...is this a car that sits for extended periods of time? (6-12 months)
Michael Wiseman
May 5, 2016 12:33 AM
Mohsin
21
May 24, 2013 08:56 AM
luohaoran
Oct 2, 2010 04:12 AM
AKUFC
May 13, 2003 10:47 AM
