b18a1 swap into 91 civic hatch
Old Feb 24, 2012 | 06:38 PM
10secpat's Avatar
Icon6 b18a1 swap into 91 civic hatch
what all parts do i need to do successful swap with no major mods just stock b18a1??? any help
Old Feb 24, 2012 | 06:40 PM
Spug's Avatar
Default Re: b18a1 swap into 91 civic hatch
Read this:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/detailed-b-series-into-crx-ef-civic-parts-list-more-2769325/
Old Feb 24, 2012 | 07:05 PM
ehonda87's Avatar
if your slammed you may have to use accord radius arms. my buddy had a b18 swapped ef hatch and the crank pulley almost cut the radius arm in half from grinding on it haha
Old Mar 1, 2012 | 11:48 AM
10secpat's Avatar
thanks alot
Old Mar 1, 2012 | 02:05 PM
Blasney's Avatar
From: On the road...generally in the central United States...
At the very LEAST, you'll need a set of aftermarket engine/transmission mounts, a 1990-93 Integra rear engine t-bracket, a 1990-93 Integra driver's side engine bracket, a 1990-93 Integra throttle cable (for a clean, factory look...or an adapter bracket to use the existing cable), along with 1990-93 Integra axles and intermediate shaft. Add to that list an exhaust system of some sort, a Del Sol or Civic Si radiator is a good bet, and radiator hoses for a 1990-93 Integra and you'll have the bulk of what you need to get started.
I have an 89 sedan with a basically stock B18A1 in it and it's a very nice and reliable combination. I'm a big advocate of the cheap and easy to find B18 engines myself...and I think you will be too once you take yours for that first drive!
eap
Jan 19, 2009 08:11 AM
integrawow
May 28, 2007 06:04 AM
JDMVTEC
Oct 30, 2003 07:26 PM
myflysi
Aug 15, 2003 11:44 AM
Aquafina
May 20, 2003 03:02 AM
