RSX; Heater doesn't work
Old Feb 24, 2012 | 03:18 PM
SleepyEasy's Avatar
Default RSX; Heater doesn't work
I drive a 2006 rsx base model and the heater doesn't work. A few days ago it was working fine but now it doesn't. I let the car warm up but still no hot air was blowing and when I drive its still blows cold air. Can anyone help?
Old Feb 24, 2012 | 03:41 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: RSX; Heater doesn't work
Check the thermostat
Old Feb 25, 2012 | 04:04 AM
tai....'s Avatar
i had the same problem with an rsx..i checked under the center dash and found that the wire that was hooked up to the vent motor was off so it wasnt switching it to hot just left it on cold
Old Feb 25, 2012 | 09:33 AM
SleepyEasy's Avatar
the thermostat works fine.
i'll check and see if it is connected.
Old Feb 25, 2012 | 02:30 PM
AndrewBeckett's Avatar
I'm having the same problem with my ep3, it seems like the cable that switches the hcv from hot to cold is seized, I popped the cable off and the hcv moves freely...
Old Feb 25, 2012 | 09:44 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
pop the hood... put it on cold and look at the valve... then switch it to hot and see if the valve opened up
Old Feb 29, 2012 | 09:16 AM
ahmad-a's Avatar
I've heard something with the relay's go bad on these cars.
Old Feb 29, 2012 | 05:00 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
or do you mean the blower motor resistor? I've seen talks about those going bad... but they only control the fan speeds
Old Jul 10, 2020 | 11:30 PM
Jorge Salazar's Avatar
like where under the dash? On the side by the mode controller where the acelerador pedal is at? Or actually under the dash? Sorry I just really need too fix this before it snows I live in Colorado.
CARRIEV
Mar 17, 2017 06:10 PM
ekhatchey
Nov 23, 2010 03:39 AM
aztecadam
15
Dec 11, 2008 06:46 AM
adicted2nothing
Apr 2, 2005 11:16 PM
Infinity_Racer
Oct 17, 2002 09:37 AM
