Help with trailing arm
Old Feb 24, 2012 | 12:18 PM
eg0's Avatar
eg0
Default Help with trailing arm
Hey guys, looked around for info but cant find alot on this, So here it is I have a 1993 del sol with a rear disc conversion. (unknown from what car) Trailing arm bushing was done, Decided to replace it. When pressing the bushing out, I bent the trailing arm slightly. Now its 4pm at the shop, there closing down and I have to hury and press the new one back in. Thats when I found out that the new bushing is too small. I pressed the old one back in and slapped it on the car.
Now I have a rear right tire thats toed in and causing a nasty pull and vibration.
So now I need a trailing arm, But off what car? I asked around at local shops and they tell me that there is only one part number for all acura/honda rear trailing arm bushings that will bolt up to my del sol.
I measured the old bushing and it was about 3.35 inches.
The smaller bushing (aka what everybody keeps telling me will fit ) is 3.17 inches.
So heres the big question, What trailing arm takes a 3.35inch bearing that bolts up to my eg del sol and what car is this from?
Old Feb 24, 2012 | 12:25 PM
sw388's Avatar
Default Re: Help with trailing arm
Just a shoot in the dark here, with no facts. I would assume Integra rear trailing arms.....they are the most commonly available rear disc upgrade. I have not measured but im sure the part numbers for aftermarket bushings will support this theory....sadly they wont tell you dimensions.
energy suspension says:
16.7106 civic 88-00
16.7106 tegs 94-01
16.7107 90-93 tegs
they could be DA since they are the odd ball of the group. gl
jedhobbs
Mar 9, 2019 08:30 AM
cdruhm89
Nov 20, 2017 07:12 AM
EG2DelSlow
Sep 6, 2011 10:54 AM
d16z6_ej1
Jun 4, 2009 01:29 AM
