91 civic not cranking over need help
Old Feb 23, 2012 | 10:41 PM
JLW's Avatar
JLW
Default 91 civic not cranking over need help
any advice i know the engine is not seized i toojk out both half shafs and it spun freely at the crank shaft need help
Old Feb 24, 2012 | 04:51 AM
90civic-ZC's Avatar
Default Re: 91 civic not cranking over need help
We need alittle more info and discription to help you bruh......what you said is very vague.
Old Feb 24, 2012 | 04:52 AM
crvtectim's Avatar
Yes, is it turning over by key but not firing up?
Old Feb 24, 2012 | 10:28 AM
JLW's Avatar
JLW
it wont crank over at all but when i took both half shafts out it spun freely im thinking the tranny might be bad but idk it wont compression start either
Old Feb 24, 2012 | 02:07 PM
crvtectim's Avatar
So it didn't turn over when both half shaft and cv axle were installed? Is compression start another way of saying push start?
Are you hearing the starter kick out and contact the flywheel in an attempt to turn the motor over?
Old Feb 24, 2012 | 02:21 PM
ultrajuan33's Avatar
With a good charge on the battery, the starter motor is strong enough to move the car forward without the clutch depressed. Regardless, when you push the clutch the tranny is out of the equation(unless the clutch is broke or something is stuck in there)...so if the starter is actually working and trying to spin the flywheel but can't then the motor is locked up. You can try to spin the engine at the crank pulley to confirm this (spark plugs removed makes it easier). If the engine spins by hand I would say you have a bad starter, clutch switch, or ignition switch or blown fuse. Either way the vague amount of information provided leaves form even more speculation than you would already receive from an internet diagnostics. Good Luck
Old Feb 24, 2012 | 03:31 PM
90civic-ZC's Avatar
Ok JLW....work with us a little bit.....You put the key in the ignition, turn it to start....then what?
Have you checked the main ingredients? cam and crank timing, ignition timing, fuel, spark, and compression.....
When the key is in the second position does the CEL come on for two seconds and simultaniously you hear the fuel pump prime? (a humming sound for like 2 or 3 seconds)
When you turn the key does it turn over?
When you turn the key does it NOT turn over?
Old Feb 24, 2012 | 06:23 PM
Brent636r's Avatar
If delsol92 were here, sounds like he would know whats up...
Old Feb 24, 2012 | 06:28 PM
crvtectim's Avatar
el oh el
brandejo
Sep 22, 2013 03:41 PM
fivecrew123
May 29, 2013 02:00 AM
jdav
Dec 20, 2007 09:03 PM
ludetrouble
Mar 31, 2007 04:31 PM
sirex89
10
Sep 12, 2004 03:02 PM
