How do I wire this distributor?
Old Feb 23, 2012 | 10:26 AM
Corksil's Avatar
Default How do I wire this distributor?
Hey I have a 90' Civic wagon with d15b2 (dpfi) that has a leaking distributor.
I have a distributor from a 90' CRX dx (mpfi-converted) and I want to make it work on the 90' civic wagon.
The two plugs are the same, and the wire colors look the same.
However there are two extra wires (both blue) that come out of the distributor and it looks like someone wired them up aftermarket.
I internally, the distributors look different. How can I make this work? Thanks.
Old Feb 23, 2012 | 10:28 AM
Corksil's Avatar
Default Re: How do I wire this distributor?
lemme find some pics...
24TEN's Avatar
PHANTOM MENACE
MPFI distributor has an extra sensor (that's the two extra wires, blue/yellow and blue/green). I don't believe that you can use it with a DPFI set up.
Old Feb 23, 2012 | 10:36 AM
Corksil's Avatar
this is the distro i have on the civic and the square dpfi plugs on it.
the one from the crx looked like this, with 7 pin round mpfi plugs on it. someone wired the square plugs onto it and the two extra blue wires are just loose.
I tried grounding/powering/connecting the two extra wires and I couldn't make it work.
The car starts and dies instantly, as if there's an electrical cutoff. It has code 8 which is TDC sensor I believe.
how do i make this work?
Old Feb 23, 2012 | 11:00 AM
crx_si-r's Avatar
You can't. Internally the gear is different. I believe DPFI is only a 4 point while mpfi is 16
Old Feb 23, 2012 | 11:08 AM
24TEN's Avatar
PHANTOM MENACE
I don't think you're quite getting it. If the MPFI distributor has an EXTRA sensor, a sensor which has two wires which I called out by wire color, then you should be able to understand that the DPFI distributor DOES NOT HAVE this sensor or the corresponding wires. So if you're still DPFI on your wagovan, what do you think hooking up those two EXTRA wires is going to accomplish?
Now if you're MPFI converted on your current D15B2 on your wagovan then yes you would need to wire up those two EXTRA wires. So the question now is, are you MPFI converted on that car you are trying to get running?
For the record I cannot say whether a MPFI distributor will work on a DPFI setup with the extra sensor not connected.
EDIT: "crx si-r" explained why it won't work.
Old Mar 6, 2012 | 08:51 PM
Corksil's Avatar
Thanks guys, long story short - I can't wire up this dizzy.
MPFI and DPFI are completely different ECUs, I/M, injector resistor box - delete... etc.
I have ordered a new distributor today and it should be here soon.
Problem resolved, thanks HT.
Old Mar 6, 2012 | 11:06 PM
netfreak's Avatar
Weird. I was able to start my MPFI CRX using a DPFI distributor with an adapter I made (though it was in limp mode due to the missing cylinder position sensor which uses the two blue wires). Don't see why it wouldn't work the other way.
Old Mar 10, 2012 | 07:14 PM
tanjulio's Avatar
Just for future reference. The MPFI distributor has a sproket with 16 teeth spread in equal gaps; I believe it is the Crank sensor While the distributor has this sam sprocket with 20 teeth but not all teeth are spread equally. The dpfi distributor will run your car but will be in 'limp' mode and send check engine. The extra sensor on MPFI distributor is NOT the problem it is the sprocket for the Crank sensor.
Old Mar 10, 2012 | 09:09 PM
netfreak's Avatar
Ahh good to know. Glad I lucked out finding a brand new MPFI distributor at the junkyard instead of wasting time ghetto rigging the DPFI one.
Old Mar 11, 2012 | 10:34 AM
Corksil's Avatar
yeah i bought a new dpfi one as well. 160usd shipped from rockauto, i think it was remanufactured.
yes i can vouch for what tanjuilo said, it's all correct. i took them both apart and compared the internals, they are very different inside.
the car would not run in 'limp' mode, it just fired up and died instantly like a fuel-pump cutoff switch.
anyways thanks for the shouts.
team_hirev
Mar 9, 2009 03:01 PM
Iron_Forrix
May 7, 2007 09:50 PM
benihana881
Jul 21, 2006 10:01 AM
blackie
Jul 11, 2005 02:21 PM
cokinut
May 1, 2004 07:15 PM
