Everything on my cluster stoped working!
Hey guys.. So I was driving and I went to put on my turn signal and it wasn't cutting on. I look at my cluster and nothing was working but my speedo, the couple lights in it that actually do work, and my high beam are the only things working. I turn the car off and then I turn the ignition on before I start it up and the only light that turns on is my battery light. My cel, door, e-brake nothing works, no rpms nothing, no temp gauge & no gas gauge. Also my clock stopped working a couple days ago. After I get home and everything I unplug the battery for a bit and check all my fuses, do a once over of the wiring and everything seems to be ok.
Could anyone help me out please!
check all fuses. replace as necessary.
remove gauge cluster and inspect it and the wiring leading to it.
use multimeter to determine if voltage is present at the gauge cluster harness, and that you are getting solid ground to correct wires.
report back to us and let us know what you find.
91hatchcivic
Lighting
Apr 14, 2008 11:16 AM
I Gotta Question
Feb 20, 2004 03:55 PM
