why did my '92 ex just stop running on me???
Old Feb 22, 2012 | 08:08 PM
hatchinprogress's Avatar
Default why did my '92 ex just stop running on me???
ok the car is actually my girlfriends its a '92 ex (auto) everything all stock!
replaced an old (almost) dead batt. bout 3 months ago with a new battery...everything has been fine..... a few days ago the battery light came on(stayed on) but was running ok i looked 2 the batt termenals an the neg side was lose (i hadent fixed it)
today on way home car started running a lil rough and felt bogged down we parked in the closest parking lot, popped hood every thing looked fine(just visual check) started car again still seemed bogged down then after hittin gas (still in parkin lot) bogged feelin left...then car just died!! jumped car again an died right away....and stays dead...last time i jumped it 2day it barley started!!!
oh and stock tach now stays on 0 and 2 times bounces around(w/out car moving)
please i need this car runnin asap without it we dont work!!
could the battery be dead cuz it didnt have a solid neg. connection?
Old Feb 22, 2012 | 08:40 PM
seanbev24's Avatar
Default Re: why did my '92 ex just stop running on me???
Obviously you need to fix the connections, but it sounds like you may have a bad alternator
Old Feb 22, 2012 | 09:18 PM
oh ok thank you 4 the advice....some1 else also said that earlier as well...thanks again
Old Feb 23, 2012 | 07:55 AM
Ok *fingers crossed* time to try an figure this out...hope its simple
Old Feb 23, 2012 | 10:20 AM
95 H22a acclude's Avatar
with the car running,disconnect positive on battery. if it shuts off its the alternator.
Old Feb 23, 2012 | 05:55 PM
car wont stay running fr me to test it. well batt is dead it tested @ 11.51volts and i cant figure out how to replace or even get to the alternator for the life of me....HELP!!!! (it has a/c an powersteering)
Old Feb 24, 2012 | 06:43 AM
whoops...btw its a 1990 not a 92 if hat makes a difference
Old Feb 24, 2012 | 03:02 PM
holmesnmanny's Avatar
no diff
Old Feb 24, 2012 | 05:28 PM
seanbev24's Avatar
To remove the alternator, you need to move the PS pump. Loosen the bolts and take tension off the belt. Remove the belt, then remove the bolts all the way. Leaving the PS hoses connected, pull the pump up out of the way. To get more slack with the hoses, pull the PS reservoir up off it's bracket.
Make sure you disconnect the battery before unplugging the alternator.
Old Feb 25, 2012 | 12:42 AM
It would be best to change out the power steering reservoir hoses when you move it as it will tend to leak a bit when the hoses get moved and the hoses are already pretty old. You can get them cheap at auto stores. Just make sure to get some power steering fluid as well.
Like he said the alternator has an always hot power terminal. It's best to disconnect the battery before messing with it as you could be in for a big shock if you touch that terminal and any nearby ground at the same time.
Old Feb 26, 2012 | 05:14 AM
Lost Again's Avatar
Are you sure there isn't an ignition issue as well? If you jump start it, will it stay running-leave the cables connected.
Old Feb 26, 2012 | 05:34 PM
vtech0010's Avatar
describe your problem in detail. you will getting better help. when you say it doesnt not start. does it crank over? or does it crank and not start? when you were driving before it died, was the battery light on?
sbrambo
Mar 7, 2016 03:08 PM
flyinkman
Mar 3, 2013 07:17 AM
vshc82870910
Jun 19, 2010 12:52 AM
Spug
Feb 12, 2007 01:21 PM
rasta420
19
Jan 1, 2004 02:23 PM
