Swap Issue - A/F Question
Old Feb 22, 2012 | 05:54 PM
WallaceB18's Avatar
Default Swap Issue - A/F Question
Hey HT!
I put together an LS Hatch a few years back and then got sucked away to college. I finally have graduated and am getting back around to sorting this **** out. Took it to the smog ref for two tests to get the swap BAR'd but wasn't able to pass the emission tests, passed the visuals. I failed for high NOx levels and from inputting the data from the emissions into a lambda calculator my A/F looks like it is around 15.49. This is too high and is most definitely the reason my combustion chambers are hot blowing NOx and I'm seeing a little white smoke when I try to bump off the rev limiter. Antifreeze levels are topped off and oil looks clean. Timing is 14 BDTC but I am going to reset it to be certain nothing has changed. Battery is dead so I'm guessing ECU is resetting every time I jump the car. What are my options to getting the car to run a bit richer. My thoughts are giving the O2 sensor a little clean since it is a hardly used Denso (bought it new about 200 miles ago). Not pulling any codes...Have an AEM fuel rail on the b20 I pulled out of the car. I'm new to this but have tools and can do the work. Any input would be greatly appreciated. Thanks HT
Old Feb 22, 2012 | 06:45 PM
mouab18c1's Avatar
Default Re: Swap Issue - A/F Question
Why is your ignition timing not set to 16* BTDC?
Old Feb 22, 2012 | 07:19 PM
WallaceB18's Avatar
I had retarded it to try to lower NOx levels on my second smog attempt. Still at that setting.
Old Feb 23, 2012 | 11:55 AM
WallaceB18's Avatar
Okay, did the jumper and set timing to 16 BTDC. Can't really tell a difference in the way the car runs but hopefully the combustion chambers can.
masijdm
Mar 27, 2009 04:23 PM
jdmsir96
Jun 13, 2008 09:10 PM
dskater411
Mar 24, 2008 09:00 PM
