T1 Ultimate Ignition Kit:Looking for Reviews
Old Feb 22, 2012 | 04:41 PM
danedoremus's Avatar
Default T1 Ultimate Ignition Kit:Looking for Reviews
I am wanting some reviews on this kit as to see if anyone has seen stock OEM ignition to this kit on a dyno showing better results? how well was it to install? any thing fail while using it on your car?
Old Feb 22, 2012 | 04:57 PM
mtber's Avatar
Default Re: T1 Ultimate Ignition Kit:Looking for Reviews
You do realize the T1 trigger kit only works on a standalone like aem, motec etc correct?
Old Feb 22, 2012 | 04:59 PM
yes i do,i will be using AEM EMS 2
Old Feb 25, 2012 | 04:07 AM
xenocron's Avatar
If you install that kit, and get the car properly tuned...you will not have issues at least with your ignition system. This is as solid as it gets!
Old Feb 25, 2012 | 09:10 PM
locash's Avatar
Works great on my car, I won't use anything else.
Old Feb 26, 2012 | 06:33 AM
thanks for the input,are you running AEM EMS 2?
Old Feb 27, 2012 | 08:15 PM
locash's Avatar
Nope, Motec here.
Use his kit with the Pro10 box on the S300 cars all the time too, works great. Indub's 8 second civic is using that..
Old Feb 28, 2012 | 01:43 PM
Nope, Motec here.
http://store.evans-tuning.com/t1-m-w-pro-10-kit.html
This setup? and i can still use coilover plug?
also what is your views on the hondata CPR kit?
Old Mar 6, 2012 | 08:34 AM
locash's Avatar
We use that exact T1 kit on Indub's 8 second Civic, and have used it on a lot of other cars as well. It works very well. I normally stock that kit as well.
The Hondata CPR kit works well also, but will only work with the Hondata S300. The CPR kits are very hard to come by, due to limited production numbers. Whenever I get them, they sell out within a day or two.
johnvandyk
Mar 12, 2013 03:38 AM
johnvandyk
Mar 12, 2013 03:31 AM
Black Si
May 12, 2005 04:37 AM
romoracing
Dec 23, 2004 09:20 PM
