ep3 help
Old Feb 22, 2012 | 01:31 PM
purovalluco01's Avatar
Default ep3 help
ok i have an 03 ep3.,it was giving me bad codes due to a bad o2 sensor. i replaced it and all codes are fine except speed sensor. the car has a hard time starting at first and isles bad and odten turns off. this happens after the engine light comes on and only reads speed sensor. then i erase codes and it works well. can a speed sensor cause this?
Old Feb 22, 2012 | 05:41 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: ep3 help
What is the actual code that comes up
Old Feb 22, 2012 | 07:23 PM
SickSi99's Avatar
If the speedo and odometer aren't working it's a good chance the VSS is either damaged or the wiring has been damaged. Check the wiring first.
Old Feb 23, 2012 | 07:16 PM
Its code for speedometer only. Right after swit hing the o2 sensor car has developed trouble starting. Getting a headache. Once car started car runs well. Idlerains stable untill the check engine light comes up with speedo code p500. When I go to work on the morning at 4 am car turns on on first crank flawlessly. When I get out at 5 pm car takes alot of cranks and gas pedaling to turn on. Just bought the car and its driving me nuts
Old Feb 23, 2012 | 07:19 PM
And yes speedo and odo not working. Part comes in tomorrow. Thing is it was turning on fine untill I switched the o2 sensor
Old Feb 24, 2012 | 05:45 PM
ok well i just got a bad TPS code so i ordered that online. Meanwhile i checked all connections and sprayed Throttle body cleaner on car and i got to say it worked pretty darn well. Anyways about the speed sensor, im going to have to live with it untill tranny needs a rebuild. Its a 6speed tranny from an rsx that got swapped in the ep3. Whoever installed didnt make it easy for the speedometer to be placed.
Tank_EM2
Honda Civic (2001 - 2005)
Jul 1, 2014 03:28 PM
mtime
Dec 17, 2009 09:17 PM
greyejcoupe
Oct 3, 2009 10:48 AM
BAZ
Apr 26, 2004 01:45 PM
neumonik
Sep 3, 2002 06:42 AM
