Emulating with Ostrich 2.0 and TurbEdit 3.2.2
Old Feb 22, 2012 | 12:31 PM
crx_ed9's Avatar
Icon3 Emulating with Ostrich 2.0 and TurbEdit 3.2.2
Hello Everyone,
Tuning is pretty new for me and I am having trouble making the Ostrich 2.0 work with TurboEdit 3.2.2.
I have a Honda CRX ED9 1990, with a PM7 ECU OBD0. I have got a chip installed in the ECU by icedfluid http://forum.pgmfi.org/viewtopic.php?t=8161 and so far everything works just fine. However I want to emulate my ROM with the Ostrich 2.0 using TurboEdit 3.2.2 but I don't how to make the emulator and 'point tracking' work. I can send the ROM to the Ostrich 2.0 (and download it if I want) using TurboEdit 3.2.2 but when I plug it to the ECU with the file loaded in the Ostrich 2.0, the ECU sets itself to "Safe Mode" (the LED of the ECU stays on when i turn the key in the ignition)... I tried loading different maps but same results. When I put the EPROM back the LED goes off when i turn the ignition key and the car starts just fine. From what i see, putting the emulator off the socket and on gives the same resultats ('Safe Mode'). So far I have checked the following:
- The batterie in the Ostrich 2.0 displays 2.9Volts
- The switch on the Ostrich 2.0 are set up for 28 pin EPROM
- The cable connection with PC works just fine (I can communicate with the Ostrich 2.0 using TurboEdit 3.2.2)
Maybe I am not doing it right, could you by any chance help me out with that?
I look forward your answers.
Thank you all!
Moog_enep3
Feb 11, 2016 03:19 PM
kriz2fer
Honda S2000
Sep 3, 2011 12:25 PM
dc5campo
Engine Management and Tuning
Nov 7, 2010 05:15 PM
nick91civicsi
Oct 25, 2009 03:27 PM
gshatch
10
Mar 20, 2009 05:48 PM
