95 Lude - h23-f22b swap
Old Feb 22, 2012 | 10:57 AM
Phat4Door's Avatar
Default 95 Lude - h23-f22b swap
Ok guys, first off I have searched to no avail, hence this thread. I am doing this swap for a distant relative of my fiancee. He had a 95 lude with a h23 that blew up, and he got a f22b short block. The distributor cap was broken in shipping, when I tell them to get a new one, what kinda of car/motor should they order it for? Also, I'm assuming from what I read the flywheel, clutch, h233 tranny, and axles will all work for this swap. Any problems with the mounts? And he plans on using the h23 ecu, any thing I need to do other than tap threads for the knock sensor? Any guidance on this would be much appreciated! Thanks! (by the way, first time working on a lude, always been with civics and tegs)
Old Feb 22, 2012 | 06:29 PM
hondasdohc's Avatar
Default Re: 95 Lude - h23-f22b swap
I don't think you need to tap for the knock sensor unless you have an h22 they are the only h block with a knock sensor no knock on f series. The f22b he got is it a b1 or just straight b because they are different one is a single cam block the other is a dual cam block. you can use the h23 ecu and everything from the h23 trans flywheel ect. dizzy cap if it's external then use the h23 cap if its internal coil just get a internal coil cap.
Old Feb 23, 2012 | 09:08 AM
Phat4Door's Avatar
hence my problem, what cap do i get for the internal coil, i can't find one that isn't external....
Old Feb 23, 2012 | 06:31 PM
hondasdohc's Avatar
92 civic cap works and also accord caps and any honda with the distributor that looks like a 92 civic distributor cap without the external coil wire coming out of it. Also if your using the f22b distributor use the firing order for that distributor cause it will misfire. What type of motor is it single cam vtec or the dual cam non vtec?
Old Feb 24, 2012 | 10:54 AM
Phat4Door's Avatar
thank you, it's an f22 dohc non vtec
Old Feb 24, 2012 | 11:58 AM
rebuild_it's Avatar
this is where i got my info when i got my lude with the dohc f22b
click here
not-a-stang
Mar 4, 2009 11:33 PM
ImprtTuner88
Sep 20, 2006 12:25 PM
92hondalude
Sep 4, 2005 06:17 PM
F22bPrelude
Oct 6, 2004 06:40 AM
LudaKris
May 17, 2003 07:13 PM
