Suspension & Brakes Theory, alignment, spring rates....
G/C Koni Setup EF9, Rear sitting uneven, what to do.
Old Feb 22, 2012 | 08:43 AM
egyolk's Avatar
Default G/C Koni Setup EF9, Rear sitting uneven, what to do.
Car: 1991 Civic Si Hatchback
suspension: Ground Control Koni Yellow's with off the shelf spring rates
Wheels: 14x7 +27 Front +32 Rear
So here's the situation..
I recently adjusted the height of all four corners of the car because the front was rubbing on to the fenders and the rear was just too high up. After raising the car in the front (by adjusting the collar on each perch on the front two corners) and putting the car back down the car sits even in the front with equal gaps between the tire and the fender. HOWEVER when I had adjusted the back two corners EVENLY and put the car back down, I found that the right rear was perfect, where I wanted it , with about 1.5 CM gap.. BUT the left rear was tucking and the tire was very close to the fender, enough to rub going over any bump...
What is causing this unevenness? I know it could be chassis flex because this car 21 years old, or I've read somewhere that maybe the alignment is off causing the illusion that it's tucked on one side and a 1 1/2 cm gap on the other...
What should I do? Can I just raise the left side more than I have the right so that the car will appear to have equal gaps on both sides? If alignment will fix this I worry that if I raise the left rear more than the right rear to compensate then after alignment is done my car will be off again?
either how I need help..
Cliffs: height adjustable G/C Koni Setup, rear left and rear right adjustments made on the collar/perch are identical but car sits uneven in rear. Should I raise left side to compensate? I want to get alignment but I really want to have the perfect ride height before I go and get it so I won't have to make adjustments after the alignment....
Old Feb 22, 2012 | 08:53 AM
grumblemarc's Avatar
The Grumpiest
Default Re: G/C Koni Setup EF9, Rear sitting uneven, what to do.
You're making it harder than you need to. Adjust each corner as needed.
Old Feb 22, 2012 | 09:46 AM
egyolk's Avatar
PM'ed Grumblemarc, Bump for more help!
Old Feb 22, 2012 | 10:18 AM
abs0Lut's Avatar
adjust the perches to get equal gap, just because they're sitting in the same position doesn't mean your car will...
easy peasy lemon squeezy
Old Feb 22, 2012 | 10:41 AM
egyolk's Avatar
but why is that? when the stock suspension is on there its not like the spring lengths are different to compensate for gaps... if everything is sitting in the same position shouldn't the car? minus chasis flex minus alignment issues minus possible incorrect install of said suspension
Old Feb 22, 2012 | 10:43 AM
egyolk's Avatar
Originally Posted by solbrothers
Don't forget that it'll sit different with someone in the drivers seat.
hmm but this is the rear left? its like tucked where you can stick a finger in where the fender meets the tire and on the right side its like a 1.5 cm gap
the171
Suspension & Brakes
Jan 26, 2017 04:10 PM
egyolk
Feb 22, 2012 04:56 PM
Pinja
Suspension & Brakes
12
Dec 4, 2008 02:07 PM
See Are X
Suspension & Brakes
Nov 7, 2008 09:08 AM
DA9 Integra
25
Jun 22, 2006 02:57 PM
