d16y8 block d15b7 head
Old Feb 21, 2012 | 08:19 PM
honda2uner0521's Avatar
Default d16y8 block d15b7 head
I've got a d16y8 block and a d15b7head wasn't sure if the would work together.
Read a few things that said they would but still kinda sceptic. Didn't know if any one had any solid exp. I don't wanna blow anything up..lol but what I've researched and found is if you use a d16 cam and gear with the d15 head it would be fine. But which head bolts do you use and which timing belt and what kinda problems would I be facing. If anyone could help it would be awesome.
Old Feb 21, 2012 | 08:41 PM
94EG8's Avatar
Seagull Management
Default Re: d16y8 block d15b7 head
It'll work, but it's going to be gutless, that combo is going to be low compression, 8.73:1
Headbolts should be for a D15B7, timing belt will either be for a D15B7 or a D16A6 (I think the latter)
Old Feb 21, 2012 | 09:59 PM
Texas4door's Avatar
Hmmm...low compression....perfect for a mild turbo build then!
Old Feb 22, 2012 | 02:33 AM
@94EG8 see I was told the opposite I was told it would be sick.
Old Feb 22, 2012 | 03:25 AM
94EG8's Avatar
Seagull Management
Nope, sorry. Next time someone tells you that try crunching the numbers on it:
http://www.zealautowerks.com/dseries.html
Old Feb 22, 2012 | 06:18 AM
24TEN's Avatar
PHANTOM MENACE
This should help get you started. Can't say which head bolts you'll need though.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-d16z6-block-d16a6-head-2754616/
92ehatch
Jun 2, 2009 07:11 AM
Ch3mik
33
Oct 30, 2007 08:21 AM
Civiclized
Sep 28, 2006 08:46 AM
scarface50370
Oct 1, 2005 11:50 PM
Jockobo
May 24, 2004 04:44 AM
