440 injectors + fmu
Old Oct 9, 2002 | 08:23 PM
slowsi00's Avatar
Default 440 injectors + fmu
can i run 440 injectors on a stock ecu???
with a fmu??
i have a resistor pack if thats what i need.
by the way no v-fac
Old Oct 9, 2002 | 08:25 PM
blufke's Avatar
Default Re: 440 injectors + fmu (slowsi00)
have you looked at the new smc? search for smc.
Old Oct 9, 2002 | 08:27 PM
slowsi00's Avatar
Default Re: 440 injectors + fmu (blufke)
no time
i need this by tomorrow night
i was going to have the stock injectors but i want to upgrade
the shop does not have 310 but they do have 440's
Old Oct 9, 2002 | 08:42 PM
slowsi00's Avatar
anyone else??
Old Oct 9, 2002 | 09:32 PM
slowsi00's Avatar
hmm anyone
not to be anyoying or anything but i really do need the info...
Old Oct 9, 2002 | 09:33 PM
SIK IN DA HED's Avatar
New User
no... i wouldnt recommend it. your idle will be off.
Old Oct 9, 2002 | 09:39 PM
slowsi00's Avatar
Default Re: 440 injectors + fmu (dlplayboy)
hmm i reall don't care if its a lumpy idle
i just want to know if it will work a little lumpy idle is all good for me...
Old Oct 9, 2002 | 10:16 PM
zojirushi's Avatar
your gonna need something like an afc to idle those 440's
plus with the fmu setup, u need a map limiter.
Old Oct 10, 2002 | 12:17 AM
Cramerox's Avatar
not goign to work with no vafc. your car will just die.
Old Oct 10, 2002 | 12:16 PM
slowsi00's Avatar
Default Re: 440 injectors + fmu (Cramerox)
thanks
Old Oct 10, 2002 | 12:20 PM
Evil EG's Avatar
I take it your AEM EMS is not working well.
Old Oct 10, 2002 | 12:35 PM
Adi Radoncic's Avatar
On Fire!
slowsi00
There is no way your car is gona Idle with 440's and a 12:1 ratio FMU without any electronics. I have the same thing on my gsr and with my vafc I leaned the system out -38% to get it to Idle nice...
If you have the option try a 8:1 ratio disk and it should work good for you without electronics...
Adi
Old Oct 10, 2002 | 12:40 PM
Screaminz28's Avatar
Default Re: 440 injectors + fmu (newgsr)
It should ide, just not the best. I have run a car with 440s on the stock ecu before. The hondata box locked up once, and we ran on the limp home maps for a day, then we found out there was a problem when we tried to go to boost. We were also running 60 lbs static fuel pressure. I wouldn't have thought it would run right at all, but it did. The FMU shouldn't make a difference below boost.
Old Oct 10, 2002 | 12:48 PM
DeepSi's Avatar
Default Re: 440 injectors + fmu (Screaminz28)
i ran 440cc on my stock ecu just to test it out, and the idle was way off. it flux between 200 rpm and 1500 rpm. i dont even think you can drive this. you need something to control the fuel for them
-deepsi
flarinpnoi
Mar 28, 2004 12:46 AM
Kimbo
May 23, 2003 05:17 PM
slwazgsr
Aug 27, 2002 03:19 AM
TurboTeG4
Jul 4, 2002 04:37 PM
echo999
Jun 13, 2002 07:48 AM
