s300 help
Old Feb 20, 2012 | 07:08 PM
rfelix89's Avatar
Default s300 help
i got my car tuned. runs fine. i came home uplaoded smanager on my laptopn then hooked up the usb to make some changes to my launch control and boost control. but i cant make anychanges all the options are just invisible is there a certain procedure to follow before i can tinker with my settings?
Old Feb 20, 2012 | 08:29 PM
mtber's Avatar
Default Re: s300 help
I recommend you contact your tuner & ask the tuner to email you the original tune calibration.
Otherwise you can connect to the ecu by connecting the usb cable to the laptop/ecu, turning the ignition key on & clicking online then download.
Old Feb 20, 2012 | 10:40 PM
rfelix89's Avatar
thanks for ur reply. but will that erase my tune or just give me the ability to modify it?
Old Feb 22, 2012 | 06:25 AM
Will_SG's Avatar
As mtber mentioned
->connect to the ecu via usb cable to the laptop -> key to ignition position -> Smanager -> online -> download.
Then "save as" whatever file u want, so that u can revert back to the settings done by your tuner in case u screw up.
After which, u can start modify the settings u want and upload (Online->upload)
nu2teg
Engine Management and Tuning
Dec 10, 2012 02:03 PM
EG93si
Oct 10, 2005 08:51 AM
spike
Jul 17, 2003 08:30 PM
soundman
May 1, 2003 10:50 AM
