GSR swap.
Old Feb 19, 2012 | 09:43 PM
Paul Elisha's Avatar
Default GSR swap.
I have a civic EK with a GSR swap. Im trying to get my heater working. Everything is still on the car. Core, and stock heater hoses. Only issue i have is with one of my heater hoses not fitting properly. "it is leaking really bad and has a kink it in" I need to no what hose i can use for it to fit properly. It the heater core return hose. Not the hose that connects to heater control valve.
Old Feb 20, 2012 | 04:10 PM
boostedgeezer's Avatar
Default Re: GSR swap.
Either order one for a gsr or eliminate the pipe under the throttle body and go straight from the heater core outlet to the water pipe on the back of the block with a straight piece of 5/8 heater hose.
Old Feb 20, 2012 | 06:52 PM
So a GSR hose will fit?
Old Feb 20, 2012 | 07:25 PM
mouab18c1's Avatar
Just measure the diameter of it and go buy one at Lowes.
Paul Elisha
Mar 4, 2012 11:38 AM
90efcvicsi23
Dec 4, 2008 04:31 PM
MurdersV8s
Apr 18, 2008 08:12 PM
untitledsn41
Sep 21, 2004 11:33 AM
EARLdaSQUIRREL
Aug 5, 2003 05:36 PM
