Might be a fuel problem.
Old Feb 19, 2012 | 07:56 PM
5speedchick's Avatar
Default Might be a fuel problem.
I've been having this problem where I will accelerate from a stop and about ten seconds after I've reached my ideal speed my car will let out a slight tug. The tug can be compared to driving an automatic and turning overdrive back on. Maybe I need a new fuel pump? There aren't enough symptoms yet to tell. Need some help!!
Old Feb 20, 2012 | 01:55 PM
phootbag's Avatar
Default Re: Might be a fuel problem.
torque converter clutch? do you rpms drop by about 200 when you feel the tug?
Old Feb 20, 2012 | 02:15 PM
My rpms don't change when it tugs, atleast not enough to notice. And I have a manual transmission, and the clutch works great. So no faulty torque converter. My boyfriend says maybe I should change my fuel filter but I'm not too sure.
Old Feb 20, 2012 | 02:58 PM
phootbag's Avatar
ok. doesnt sound like a plugged filter. more like a brief misfire, though. as you say, There aren't enough symptoms yet to tell
Old Feb 20, 2012 | 03:40 PM
s0lid's Avatar
check your fuel pressure first if still around 38-42 it's not the fuel system you should look at.
Old Feb 20, 2012 | 07:43 PM
I'll check that. The tug usually happens when I accelerate at higher rpms and quicker. It only happens once though.
Old Feb 21, 2012 | 12:03 AM
s0lid's Avatar
is it while accelerating or after and you're already on cruising speed? usually if it's fuel pump you won't reach high rpm
Old Feb 21, 2012 | 05:43 AM
StreetsideStig's Avatar
What year is the car? The fuel pumps are pretty die hard. Have you checked the main relay?
hotbway_jason
Nov 25, 2010 04:27 PM
djtony5
Jan 13, 2006 01:37 AM
visual
Mar 1, 2003 02:23 PM
