TRX450R
Old Feb 19, 2012 | 07:46 PM
riverrunner06's Avatar
From: recentlty moved out from under the rock and into a spacious dumpster :O)
Default TRX450R
I know this is likely out of the norm here. I would like to ask if anyone has dealt or has knowledge of the matter. I have an '04 TRX450R that the idle will not remain stable. I adjust the set screw to a desirable idle speed. then after riding a short while it will either be too high or stalls. After adjusting again I get the opposite reaction. I have cleaned the carb 4 times and nothing has been found in the float bowl the last 3 times. There is a throttle position sensor on the carb. Last summer I found that if it was disconnected the idle stablized and I did not have a problem until the weather turned cold. The bike runs great, just the idle is not stable. Any suggestions would be welcomed.
thx
Old Feb 19, 2012 | 07:48 PM
Dc4LsTeG's Avatar
EK9
Default Re: TRX450R
There's a motorcycle section here. Try there
Old Jan 30, 2014 | 09:38 AM
Default Re: TRX450R
I have dealt with this. I found the throttle position sensor was the issue. I disconnected it and got much better stability on idle. Of course replacement is the best solution. The TPS is a pricey part though.
Old Jan 31, 2014 | 05:31 PM
schneedrache's Avatar
Default Re: TRX450R
Holy thread bump batman.
Old Jan 31, 2014 | 09:21 PM
Default Re: TRX450R
LMFAO!!! I replied from my android and didn't realize that I posted this originaly... )
Angelena
Oct 30, 2008 02:52 PM
go2sleep
Jun 15, 2006 08:54 PM
choutreux
Apr 18, 2004 07:20 AM
Vp Special K
Apr 4, 2003 09:14 PM
