inconsistent idle
im having an inconsistent idle while at stop lights or in park. it sits at around 500 rpm, but when i first get it started from it being cold, the needle jumps around and it stalls sometimes. where should i be looking first? possible vacum leak? IAC valve?
Yea, I had a REALLY bad idle surge, claned the IAC, and then tightened up the FITV and its better but I still have a very small surge randomly here and there, im thinking its when the heat is turned on and the coolant is not bleed or filled properly.
https://honda-tech.com/forums/honda-accord-1990-2002-2/cleaning-iacv-fitv-tb-1844067/
Inextricabledrvr
Feb 7, 2012 08:31 AM
footstinker
Nov 6, 2010 01:09 AM
spock_rocker
Oct 17, 2007 08:11 AM
Pele
Feb 9, 2003 01:01 AM
