Bent Lca's alignment trouble
Old Feb 19, 2012 | 10:08 AM
SiRCiviC94's Avatar
Default Bent Lca's alignment trouble
car pulls very hard to the right. the rear alignment was off and used to pull slightly right, then I hit some contruction sewers and bent the front right lca back a bit and its bad now.
the car is pretty messed up from this I guess how do I go about fixing it what components?
the front is just a matter of getting a straight A arm or lca and putting everything on there? how long will it take to swap whats needed? ill be doing it as I change the suspension for summer.
the rear I dont know what to do the adjustment is probably seized. it would be nice to have it drive straight again but really dont know what to do here. a shop would charge upwards of 500$ to fix this probably and the car was less than that lol
its a ek hatch
Old Feb 19, 2012 | 10:10 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Bent Lca's alignment trouble
Trick question? Fix anything bent or broken. What am I missing here?
Old Feb 19, 2012 | 11:24 AM
SiRCiviC94's Avatar
I just have a feeling there might be more to it. as long as the lca it self is all thats bent. I looked under my other car thats jacked up it looks to be just break the ball joint loose and take out 2-3 bolts put in new lca. the rear i donno wtf
FlewByU352
11
Aug 18, 2013 09:47 AM
allmotorSOHC16
Suspension & Brakes
Oct 24, 2006 04:54 PM
chjkingme
Suspension & Brakes
Mar 31, 2005 03:50 PM
agent007ppk
Feb 28, 2004 09:31 PM
Drew96EJ
Dec 30, 2003 07:46 PM
