Suspension & Brakes Theory, alignment, spring rates....
WILL A 92 INTEGRA LS REAR BRAKE SETUP BOLT ON MY 95 EG??
Old Feb 18, 2012 | 08:20 PM
stuckagain's Avatar
Default WILL A 92 INTEGRA LS REAR BRAKE SETUP BOLT ON MY 95 EG??
Ive searched and found multiple threads on this but nothing seems to answer my question specifically, so im wondering if a rear disk brake setup origanally from a 92 integra ls and then it was fitted to a 90 crx will fit on my 95 eg. Iam unsure if that brake setup had to modded to fit the crx chassis? which will make me run into problems putting it on my eg. A local seller has the setup and its complete but needs new rotors and pads, hes asking 150 bucks. LMK what you think cause Im thinking about picking it up soon if it will work and thats a decent pric.
Thanks in advance again!!!
Old Feb 18, 2012 | 09:42 PM
stuckagain's Avatar
Default Re: WILL A 92 INTEGRA LS REAR BRAKE SETUP BOLT ON MY 95 EG??
PLEASE MOVE TO BRAKE SECTION. THANKS
Old Feb 18, 2012 | 11:20 PM
BlueIntegraBoy's Avatar
Yes it will bolt up. Make sure you buy ebrake cables from the models that came with rear disks for your generation Civic (ie Si, EX with ABS) or any 94-01 Integra 3dr.
Old Feb 19, 2012 | 05:53 AM
stuckagain's Avatar
Why cant I use the ebrake cables from the 92 integra that come with he setup?
Old Feb 19, 2012 | 08:04 AM
98civdx's Avatar
Master Detailer
Trailing arm bushings are bigger on the DA's.
Civi_eg3
Sep 24, 2015 05:54 AM
EG-SIXV-TEC
Oct 2, 2012 10:58 PM
DA9Ison
Suspension & Brakes
Apr 21, 2011 11:28 PM
Wardell
Northeast (Sales)
Apr 14, 2008 07:05 AM
