02 civic si vtec problem
Old Feb 18, 2012 | 03:51 PM
HondacivDX's Avatar
Default 02 civic si vtec problem
Heres my issue i got a P1259 code for vtec malfunction...so i replaced the vtec solenoid and the pressure switch on the side if the motor fresh 5w20 synthic oil change and this code keepscoming anything i might be over looking ..any input much thanks stumped
Old Feb 18, 2012 | 04:47 PM
Mercer's Avatar
Default Re: 02 civic si vtec problem
Not sure about the code, but i do know a common vtec problem is sometimes a bad thermostat, not totally sure if thats your problem, someone else might have a bit more info on this
Old Feb 18, 2012 | 07:01 PM
SickSi99's Avatar
Is your speedo and odometer working? Is VTEC even engaging? If not, it could be the VSS.
Old Feb 18, 2012 | 07:27 PM
HondacivDX's Avatar
The speedo works and ill check out the thermostat
Old Feb 18, 2012 | 07:28 PM
HondacivDX's Avatar
Vtec engages sometimes not all the time its qeird
Old Feb 19, 2012 | 03:25 AM
SickSi99's Avatar
Hmm...might try checking the port where the solenoid mounts to the block. Might be clogged. Check the wiring on the Vehicle Speed Sensor anyways. Wouldn't hurt.
TristanW10
Mar 15, 2010 03:33 PM
96tegsr
Nov 30, 2004 07:07 AM
cesareDOHC
Mar 6, 2004 02:53 PM
Hondasaurs
May 9, 2003 08:51 PM
89sir-9
Jun 18, 2002 11:02 AM
