Speedo not working along with odometer
Old Feb 18, 2012 | 08:22 AM
Lazysk8r2's Avatar
Default Speedo not working along with odometer
Like title says those two things arnt working, the VSS is working because my s300 shows how fast im going. I checked fuse number 15 and it was fine. Also changed out clusters with my friends whose was working and that didnt solve it. So now im stuck seems like it has to be between the ECU and cluster? i havent been able to find a wiring diagram to help me. I see the vss goes into ecu but where does it go and come from to the cluster?
Old Feb 18, 2012 | 09:49 AM
Former User's Avatar
Default Re: Speedo not working along with odometer
What car?
If code 17 is not thrown, then the wire between the VSS and cluster is probably broken.
Old Feb 18, 2012 | 01:27 PM
Lazysk8r2's Avatar
Originally Posted by RonJ@HT
What car?
Its on a EM1. I havent been able to find a wiring diagram for the VSS to cluster. And no Codes
Old Feb 18, 2012 | 02:34 PM
Cluster: Blu/Wht wire at terminal B11 of the cluster connector B.
VSS: Blu/Wht wire in VSS connector.
Is there continuity between these two points?
Old Feb 18, 2012 | 06:15 PM
Lazysk8r2's Avatar
Solved thanks for the help!
Old Feb 18, 2012 | 06:17 PM
Please share the solution with members.
Old Feb 19, 2012 | 06:51 AM
Lazysk8r2's Avatar
When i was cleaning up my harness the pin must have wiggled loose.
afterdark
13
Apr 30, 2009 10:12 AM
USDMSiR
15
Aug 31, 2006 02:07 PM
ham
16
Aug 21, 2004 10:26 AM
I LOVE MY EF9
Jan 18, 2004 10:01 PM
