EK with GSR swap. I need heat.
Old Feb 17, 2012 | 09:06 PM
Paul Elisha's Avatar
Default EK with GSR swap. I need heat.
I have a 96 civic with GSR swap. I want to get my heat working again.
What hoses do i need. One of my stock EK hoses but one doesnt. Is this
normal. Please help.
Old Feb 18, 2012 | 06:34 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: EK with GSR swap. I need heat.
You need more detail into your problem. Why isn't your heat working? Do you have a heater core and heater hoses? Is the car not reaching operating temperature?
"One of my stock EK hoses but one doesn't", Huh?
Old Feb 18, 2012 | 05:34 PM
Just have a hose fitting problem. One hose fit on the heater control valve. But the other
hose will not fit properly. It has a server kink in it and it is leaking. Any one know the
solution?
Old Feb 18, 2012 | 06:00 PM
All my old EK hardware is there. I guess what im trying to ask is that with the gsr swap what hoses must i change to get the correct fitting?
Old Feb 19, 2012 | 07:57 PM
Any one?
Old Feb 26, 2012 | 08:55 PM
coolindagame304's Avatar
Just go to autozone and get clamps and try to match the size hose you have should be 3/4 heater hose I think ?
Old Mar 4, 2012 | 11:38 AM
Sushi Boy's Avatar
heres the hose PN from the firewall to the metal tube under the gsr manifold..
79725-ST7-000 HOSE, WATER OUTLET
Paul Elisha
Feb 20, 2012 07:25 PM
Akai Star
Apr 6, 2010 09:05 AM
MurdersV8s
Apr 18, 2008 08:12 PM
ekb16
Oct 27, 2005 02:46 PM
