AEM UEGO wideband wiring
Old Feb 17, 2012 | 11:34 AM
phelpsj2's Avatar
Default AEM UEGO wideband wiring
I just got a wideband, and was wondering where you guys where getting ur 12v 10a source from and where you routed the white wire.
Old Feb 17, 2012 | 11:52 AM
BigMike0147's Avatar
Default Re: AEM UEGO wideband wiring
I used an "add a circuit" under the dash that allows you to add another fuse off of one currently there. The white wire is for the signal going to an EMS, right?? If so, I wired that to an open spot in my ECU so that my Neptune could pick it up. Need to extend the wire.
Old Feb 17, 2012 | 01:01 PM
SiRCiviC94's Avatar
just get power from the fusebox under the dash theres 5 open slots...it would be good to run an inline fuse as well
Old Feb 18, 2012 | 08:16 AM
phelpsj2's Avatar
I heard to run the white wire to d10 or d14. d14 is the primary o2 sensor spot though. wont that not work
Old Feb 18, 2012 | 08:46 AM
Whiterice-gsr's Avatar
well the aem replacemnet would then become the primary o2 right?
Old Feb 18, 2012 | 10:18 AM
racebum's Avatar
solder a wire on a 10a fuse and find a switched power slot under the dash.
if you grind away a tiny bit of the plastic on the top side of a slide in fuse you'll have enough surface area for a good solder provided you use flux for a quick fuse
Old Feb 18, 2012 | 11:50 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
hmm
anybody have any pictures of there setup?
i have the same aem wideband (currently not installed) but im going to run it separate from the oem o2 sensor
Old Feb 19, 2012 | 07:56 AM
phelpsj2's Avatar
a picture of the gauge mounted, or of the wiring? heres mine i mounted yesterday
Old Feb 19, 2012 | 10:59 AM
the wiring
mainly the fuse box area.
im not sure if mine is like yours since i have a 95 gsr
Old Feb 20, 2012 | 06:56 PM
racebum's Avatar
i just installed mine today
if you don't have running lights and fuse 16 is blank, take a spade off the hot side to an inline fuse holder then to the wideband
just in case anyone is searching in the future i mean fuse 16 for a 94-97 integra
Old Feb 21, 2012 | 03:22 AM
I'm sorry
But could you show a photo lol
I'm a visual learner
I'll have this one gauge being ran off this power source
Old Feb 21, 2012 | 12:06 PM
phelpsj2's Avatar
I finally wired mine up today, this is what i did. I got this fuse thing from discount autoparts and soldered my power wire to the fuse holder that i put in a spare fuse slot under the dash. then i put the ground behing the steering wheel.
Old Nov 25, 2012 | 04:12 PM
rel's Avatar
rel
anyone got info on wiring the serial cable for datalogging?
Old Nov 25, 2012 | 08:36 PM
BoostedDOHCGSR's Avatar
10 Year Member
for hondatas300 I wired mine up to d10. works great. Analog wire (white I believe)
Old Nov 26, 2012 | 05:03 AM
EF1.8T's Avatar
https://honda-tech.com/forums/engine-management-tuning-124/xenocron-com-write-up-diy-install-innovate-plx-aem-wideband-ems-3088834/
rel's Avatar
rel
i would love to hook to directly to my hulog
Old Jul 8, 2013 | 08:56 AM
pkopalek's Avatar
According to the AEM manual here: http://www.schnitzracing.com/manuals/AEMWBK.pdf you can set the configuration to the UEGO to P4, and use the white wire to plug into D14 of your ECU instead of your normal Narrowband O2 sensor.
HULOG should capture what the ECU is reading (since the reading will look like a normal nbo2 sensor to the ECU) and Crome Pro (or many of the other free softwares) should be able to plot that for you.
I'm about to try this today.
Old Jul 8, 2013 | 09:46 AM
Muckman's Avatar
Moderator in Chief
Technically correct but the resolution at 1v is horrible. It wont be any better than the stock O2. Look at the P4 graph.
Old Jul 9, 2013 | 01:50 AM
wantboost's Avatar
Who is Mr Robot?
Thread is old but I'll toss my hat in, having an AEM gauge type UEGO..
The white wire is a simulated analog 0-1v output, I would only hook uo that wir e if you're using a stock ecu and it needs the signal to not throw a cel/run like ****.
There's another loose wire that's a full 0-5v output. That's what gets connected in place of the oem o2 signal and the stock ecu will read 0-5v, assuming it's chipped. Your tuning software of choice should have a dropdown menu of o2 scalars. Select AEM and now your ecu will monitor real time o2 data and allow you to datalog the o2 info along with everything else.
There's no point in having a wideband if you can't connect it to your EMS of choice and monitor it as you definitely can't tune **** with a stock narrowband gauge.
Some engine management systems will even self tune the fuel map based off of the widebands 0-5v signal hooked up to it, you simply input an air fuel or lambda target value and as you drive the ecu will build a fuel map on its own.
Old Jul 15, 2013 | 08:10 AM
pkopalek's Avatar
Thanks for your reply.
I'm going to hook my AEM up to D14 and put it back into P0 mode (normal wideband 0-5v) for datalogging.
Having it on D10 doesn't work for Freelog or Crome anyway, and having it in P4 (simulated wideband) mode doesn't seem to help with that.
I have to say though, having the 02 sensor enabled is performing some impressive corrections during part-throttle driving, compared to disabling it (with the AEM connected as a narrowband simulated).
Going to just disable it though. Thanks again.
B_Swapped93
Feb 8, 2014 04:08 PM
I Love My 4 door
Dec 19, 2010 04:05 PM
oj5joker
Jul 16, 2010 08:42 PM
superfuji57
Jul 30, 2004 12:02 AM
Creepshow S60
Aug 20, 2003 10:15 AM
