b20z in ek can a crv halfshaft be used ?????
So i am helping my buddy swap out his long overdue d series and he picked up a complete b20z for a steal. We have just about everything needed but we are having some confusion with the halfshaft. The crv was 4wd 5spd so obviously we took the half shaft with us. We mounted an ls gearbox no issues(b fits fit) in most cases, slid the halfshaft on in place and everything lines up.. So my question is will the inboard joint off an ls axle fit onto the male halfshaft spline from a crv. The halfshaft part number is as follows sr3-j0 or 8 and below that is the number 16... Yes i know crvs have 36mm outboard joints and civics(ek) have 32mm.. But i am only looking to get away with halfshaft itself and use integra axles. Also i think 94-up integras on the drv side have an inside dia. of 40mm for the trans seal and 90-93 das have 35mm but what is the crv one? Hopefully someone can give me clarification on if this will work cause his car is smoking like a train as of now and the d has to go asap! Thanks for reading
SRhoades28
Jan 13, 2019 05:37 PM
cjw_89
Transmission & Drivetrain
Feb 19, 2012 07:59 AM
ottobell22
Jun 14, 2005 12:46 PM
