Should i replace my engine mounts?
Old Oct 9, 2002 | 05:48 PM
cr-x si's Avatar
Default Should i replace my engine mounts?
I am putting in my zc and i know it bolts right in but a guy told me i am better of replacing the mounts anyway cause they will probly be bad. What should i do. Should i save myself a headack and replace them?
Old Oct 9, 2002 | 05:50 PM
ScottEK's Avatar
Default Re: Should i replace my engine mounts? (cr-x si)
say he doesn't and he puts it in and he knew the engine mounts were probably bad, this is purely hypothetical , how hard would it be for "him" to change them out after the engine is in because now "his" car shakes like a mad man?
Old Oct 9, 2002 | 05:51 PM
MrTodd's Avatar
If you don't mind spending the money. When I pulled my A6 out, the mounts didn't look too bad. Just as long as the rubber isn't all cracked, you should be okay.
Mostly the front motor mount takes all of the punishment, it should be the only one needed to replace if any.
Old Oct 9, 2002 | 06:03 PM
NikoZai's Avatar
Default Re: Should i replace my engine mounts? (beta13)
so um how the hell do solid pieces of metal go bad? Rust.. but thats obvious..
The bushings are all you should need to replace.
Old Oct 9, 2002 | 06:12 PM
ScottEK's Avatar
Default Re: Should i replace my engine mounts? (NikoZai)
I wasn't aware the you could replace just the bushings, how much does something like that go for? Could I take them off one by one?
Old Oct 9, 2002 | 06:17 PM
MrTodd's Avatar
I don't think that you can just buy the rubber bushings themselves (at least OEM ones, you can buy polyurethane inserts at summit) so you have to replace the whole motor mount.
A ghetto way would be to fill in the rubber with Shoe Goe...
miketrue
Oct 20, 2010 04:16 PM
totsie7944
Feb 5, 2008 07:29 PM
sixtodc2
Jul 13, 2007 12:43 PM
vtecmike1
Nov 19, 2003 07:19 AM
ITR1071
Dec 4, 2002 06:23 PM
