Turbo single cam clutch SLIP! SOB!
Old Feb 16, 2012 | 01:07 AM
blasta510's Avatar
Icon6 Turbo single cam clutch SLIP! SOB!
Finally got my hondata back and went out for a little tuning.
And this is what I get...
http://youtu.be/Aq7A_P4-ht4
Old Feb 16, 2012 | 01:25 AM
TypeRMOBBiN209's Avatar
Default Re: Turbo single cam clutch SLIP! SOB!
dude that totally sucks
Old Feb 16, 2012 | 04:04 AM
grumblemarc's Avatar
The Grumpiest
That was surprising? This is an often overlooked aspect of turbo builds. It doesn't even take that much power to overcome a stock clutch.
So what's the question?
Old Feb 16, 2012 | 08:28 AM
blasta510's Avatar
Its an XTD 4puck extreme, with less then 2500 miles
Old Feb 16, 2012 | 08:31 AM
The Grumpiest
Well. That confirms what's been said about XTD clutches. Possibly not broken in properly.
So again. What is the question?
Old Feb 16, 2012 | 08:33 AM
NVturbo's Avatar
O.G. triple O.G.
^^^ That's your problem right there....A MEDIOCRE CLUTCH. Should've gotten a ACT.
Old Feb 16, 2012 | 08:43 AM
The Grumpiest
Why would you build a 300+hp car and put such a crappy clutch on it?
Old Feb 16, 2012 | 08:52 AM
deving916's Avatar
too much power, too much power boys
ftw
Old Feb 16, 2012 | 09:16 AM
netpsyche's Avatar
that clutch sucks
Old Feb 16, 2012 | 11:48 AM
NVturbo's Avatar
O.G. triple O.G.
ftw
no....more like too much PAINTED TRIM and white face gauge layovers. So 42 seconds ago. LOL
Old Feb 16, 2012 | 01:49 PM
98civdx's Avatar
Master Detailer
It's saying, "I want these ricer *** guages out of me, NOW!"
Sorry I had to.
Old Feb 16, 2012 | 01:50 PM
The Grumpiest
ftw
And that means...?
All that power and can't get it to the ground. FTL.
Old Feb 16, 2012 | 01:51 PM
Libertariat's Avatar
Ek Forever y0!
This is why I only buy Exedy clutches.
It is awfully tempting to save 50% on a clutch, until you see videos/pictures of slipping clutches and busted *** XTD/F1/Ebay clutches on forums.
Old Feb 16, 2012 | 02:42 PM
NVturbo's Avatar
O.G. triple O.G.
Somebody has to support and keep those crappy companies in business. Lesson of the day: If you buy crappy products, expect crappy results....
Old Feb 16, 2012 | 03:58 PM
deving916's Avatar
And that means...?
LOL was just quoting what he was saying in the video.
Old Feb 16, 2012 | 04:01 PM
The Grumpiest
My response still stands.
Old Feb 16, 2012 | 04:59 PM
Zidane6894's Avatar
Whats that saying again???
You get what you pay for....
If your not gonna build your car right why bother modifying it at all? Might as well just leave it stock and enjoy it that way. Buying cheap parts like this guy did with his clutch is just not worth the extra headache in the end to save a little $$
Old Feb 16, 2012 | 05:25 PM
94EG8's Avatar
Seagull Management
As much as people (myself included) rag on XTD clutches. I do have a friend that ran an XTD 6 puck for the last 5 or 6 summers in a GS-R swapped hatch. It was daily driven from may to november every year, absolutely beat on, it's been boosted for the last year making 320whp. and it's got about a dozen passes on it at the track since its been boosted. It was worn out when pulled this winter, but it never once slipped in all that time. For the price it really wasn't that bad. It's getting replaced with an ACT though.
If it's doing it at 2500 miles you might want to look into what caused the slipping besides "because XTD" transmission input shaft seal might be leaking, or the rear main seal. Or the disc or pressure plate might just plain be out of spec.
Old Feb 17, 2012 | 10:05 AM
blasta510's Avatar
The clutch only has 2500 miles on it.
I bought it off ebay for $149 shipped with the pressure plate.
http://www.ebay.com/itm/XTD-XTREME-4...item589210b4d2
It has worked great since i got it, grabbed great. Ill pull the tranny and see what happened.
I was thinking of just buying an act disk and putting it in there, how do you think that would work out?
Old Feb 17, 2012 | 10:06 AM
blasta510's Avatar
I have a 2 gauge pod coming in soon to replace some of the white, I bought the car with it all painted and i plan on doing a SI or crv cluster so it didn't really bother me for the time being lol
Old Feb 17, 2012 | 10:17 AM
The Grumpiest
Yeah. It's amazing how it worked. ACT and Exedy make more than one kind of clutch. How do we know how it's supposed to "work out"?
Old Feb 17, 2012 | 10:35 AM
apexi_rsx's Avatar
ive had a xtd clutch for about 4-5 years now it used to slip when it was new. now it holds but makes noises on engagement and i think thats the springs in the center are shot now. i got about 30-40k miles out of my stage 3 xtd on a boosted d. the clutch holds up if u don't beat on it every corner u turn. which im sure beating on ur car with high miles motor is going to cause leaks sooner as well. id believe the break in on these clutches is probably recommended 6 pucks are not very dd friendly but i do it fine every day. when its about to go they tend to be a pain in the ***
Old Feb 18, 2012 | 12:11 AM
boostedeg6bros's Avatar
i have a boosted d16z6 that does the same thing just need a better clutch im putting a stage 3 act clutch which should run fine with a sohc
Old Feb 21, 2012 | 11:08 PM
blasta510's Avatar
Friction material broke off the clutch.
Old Feb 21, 2012 | 11:28 PM
EsotericImage's Avatar
Retired Moderator
I have an ACT 4 puck unsprung just like that installed in 08 and still going strong. Just a few track passes on it, but mostly street driving.
(B20 boosted with 240lbs/tq)
I always said, try and save a buck and it will cost you 2 when modding a honda
topp_dawg_g
Transmission & Drivetrain
Jan 26, 2009 10:14 AM
silver-16v
May 4, 2008 10:13 AM
Pfieff
Aug 13, 2003 09:02 AM
