FS: Laskey Benson Sleeved 2.0L (B18C1) fully built AND MORE!!!
The motor was built by Mike @ Laskey Racing.Most of the short block parts have less than 750 miles on them. I have the estimated mileage noted on all parts. This motor has been tuned and built properly. It was towed to Church Automotive after assembly to have it tuned and broken in on the dyno. She was tuned for 91 octane pump gas. Motor is already pulled from the car and ready for the new owner.
Feel free to contact me at burt.truong (at) gmail.com with any questions. Thanks for looking.
http://vimeo.com/4322175
(VIDEO from previous owner)
$3000 for the longblock
95 B18C1
ShortBlock:
Benson Signature series sleeves
85mm CP Forged 11.5:1 pistons (750 miles)
Manley Pro Series I-Beam Turbo Tuff Connecting Rods (2750 miles)
ACL Bearings (750 miles)
MicroPolished / Balanced Crank (750 miles)
ARP head studs (2750 miles)
Cometic 85mm head gasket (750 miles)
Mugen Baffled oil pan
NEW OEM water pump (750 miles)
NEW OEM oil pump (750 miles)
Head:
Port/Polished head by RS Machines (7000 miles)
3 angle Valve job and inspection by Tom @ Portflow (750 miles)
Resurfaced head 2 times by Tom @ Portflow (750 miles)
Portflow Titanium retainers / dual valve springs (7000 miles)
Blox B cams (2750 miles)
Hondata IM gasket (750 miles)
JDM NGK blue plug wires (750 miles)
AEM cam sprockets (7000 miles)
NEW OEM timing belt (750 miles)
EXTRAS
1) VictorX intake manifold for B18C1 (250 miles) - $250 firm
2) JG custom road race sheet metal intake manifold - $250
3) NEW Distributor King ODB1 VTEC distributor with lifetime warranty $100 firm
4) OEM DC2 GSR axles $100 for both firm - in excellent condition - no leaks
5) Prothane shifter bushings for DA, DC, etc $15 NEW
6) Tein SS coilovers with pillowball mounts for DA $750 firm less than 3k miles
front springs are Swift 12k, rear are Swift 8k
7) Ogle rear trunk strong bar (connects rear bumper support bolts) $80 OBO
8) JDM ITR shift boot (yellow stitch) NEW $35
9) Fluidyne radiator with FAL slim fan $300
10) 93 RS black door panels good condition - $60 for both driver and passenger
11) IL4 Performance Maxx Bore Cast Throttle Body (actual throttle body for sale pictured)
The throttle body is maximum bored over to 73mm and is carefully tapered down to a 71mm back-end opening. $200 FIRM
12) RC 440 injectors (7000 miles) - $200
13) HASport 92-93 RS/LS/GS motor mounts (street) - $230 FIRM
14) RPS pressure plate + ACT street clutch (7000 miles) - $200
15) ACT 8.8lb flywheel (7000 miles) - $110
WILL GET PHOTOS UP SOON
95 B18C1
ShortBlock:
Head:
EXTRAS
bump for a nice setup. Thats exactly what I want to build/buy but with LS crank
BTW- what are you looking to get for the ACT flywheel?
Can you quote me a a price for the radiator flywheel and clutch assembly? What car is the radiator for, and is the clutch for a hydro? Thanks TTT
ambiguous
Mar 21, 2012 04:55 PM
ambiguous
Mar 8, 2012 07:31 AM
