quick radiator hose help
Old Oct 9, 2002 | 05:24 PM
leptolude's Avatar
Default quick radiator hose help
hi,
doing ES motor mounts on my prelude right now, to get at front bolt i need to make space by removing the radiator fan, in order to get the fan out of the way i need to remove the upper radiator hose. im not too expierenced a mechanic yet so i need to know:
can i remove upper radiator hose without draining coolant, or will i make a huge, paint killing mess if i unplug the thing?
Thanks for quick help!!!! sry to post this in 1+ forum, need quick help
Old Oct 9, 2002 | 06:16 PM
PrecisionH23a's Avatar
Default Re: quick radiator hose help (leptolude)
you can drain the coolant from the bottom of the radiator (in the middle)just enough so the portion in the top hose drains out. then move the 2 upper radiator hose clams so you can pull the hose off. you might make a little mess but nothing too major if you drained out enough coolant. Then refill your coolant after you replace the hose, make sure you clamp it down properly as it was before you removed the clamps. fill the coolant with 50/50 coolant/water mix till it comes up to the small hole below the radiator cap. run the car without the radiator cap until the fans come back on for the first time, put the radiator cap back on and you're done
Old Oct 9, 2002 | 07:54 PM
leptolude's Avatar
Default Re: quick radiator hose help (GudeH23a)
thanks!
did just that, just finnished up with the front mount... tomarow comes the rear.. THATS gonna be a PITA....
cheers! time
Dekorum
May 15, 2014 05:13 PM
PatrickGSR94
Aug 19, 2008 03:48 AM
plusONE jboy
Dec 25, 2004 11:23 AM
leptolude
Oct 9, 2002 05:59 PM
betsuni
Oct 25, 2001 08:47 AM
