FS/FT 96 EK FULLY BUILT SINGLE CAM VITARA TURBO, $5000
Want to trade my fully built car, but mainly looking for a swapped 4 door ek. Mainly wanting to trade for anything but with the same value of price or cash on your top,or willing to sell by offering me a price. Asking price is $5000 for whole car. Willing to work something out
Head and Bottom end is professionally built. I can show you documentation as well. Their is only 7500 miles, i have not beat on it due to me breaking the motor in.
The reason i want to trade is because i lost interest in this car and i need to worry about
college before i start to mess with cars.
Dont need people talking **** about in my thread, thanks.
Car is tuned on 8LBS OF BOOST, MADE 212 WHP, 160 TORQUE, CAR IS EASILY CAPABLE OF MAKING 300 WHP AS OF WHAT MY TUNER SAID IF I TURNED UP THE BOOST A BIT. Motor is capable of handling 400whp.
I can email more pictures to you or message you more pics.
Head- BRAND NEW OEM HONDA GASKETS
Ported and polished
Supertech Valve Springs and Retainers
Gasket matched
5 angle valve job
Bisimoto Stage 3 Camshaft N/a
Bisimoto Cam gear
Skunk 2 Pro Series intake manifold
Omnipower 70mm Throttle body
Arp headstuds
Speedfactory 4 bar map sensor
GM IAT SENSOR
HONDATA INTAKE MANIFOLD GASKET
AEM FUEL RAIL
AEM FUEL PRESSURE REGULATOR
Bottom End-
Ycp Vitara Pistons, 7:5:1 Low compression
Tuney Toy Eagle H Beam Rods
Golden eagle block guard
Ported z6 oil Pump
Tapped oil pan
Innovative 75a Motor mounts, very stiff
ARP ROD BOLTS
Trans-
S40 ex trans
7500 Miles on Xtd stage 3 clutch
7lbs flywheel
5 Speed Manual
Short shifter
Turbo kit- It was just put on, Brand new turbo, injectors, and ram horn manifold.
Precision sc44 60 trim turbo
Injector Dynamics 1000cc injectors
Go-autoworks Ram horn manifold
Tial 38mm Wastegate
Custom Downpipe, 3" pipe from turbo to Electric Exhaust cutout ( QTP) AND A WELDED 2.5" PIPE WELDED TO MY APEXI WS2 EXHAUST.
Go autoworks Pro Oil Line kit
Go autoworks Vacuum manifold
Pushlock fittings for vacuum lines
2.5" Intercooler piping
-3an Feedline
-10an oil return line
Tial BOV
Interior- i can rate it is 9-10
Stock seats
No rips
Bad-
Left quarter panel has rust
Right quarter panel is starting to rust
Trunk has 4 holes filled with bondo
hood-fenders are dented.
No dumptube for wastegate
Boost controller needs to be wired in.
When the motor was being put in
Pic of the motor when i got it back
picof the downpipe made-
Qik - Mobile video by TempUser4a2c2a088bc7dba8beec6ab0d4f384d - YouTube
Ported and polished
Gasket matched
5 angle valve job
Bisimoto Cam gear
Arp headstuds
GM IAT SENSOR
AEM FUEL RAIL
Bottom End-
Ported z6 oil Pump
Tapped oil pan
ARP ROD BOLTS
Trans-
S40 ex trans
7lbs flywheel
5 Speed Manual
Short shifter
Tial 38mm Wastegate
-3an Feedline
Tial BOV
Stock seats
No rips
Bad-
