building a street NA car
i have a honda civic EG with B16 swap on it, i just wanted to see the guys opinion about what mods to make on the car to make it fast but at the same time to keep it street able, i want to bring the maximum power out of it, but at the same time can drive it daily or in weekends without any problems, please who ever can help me please list me a full list of the needed things.
thanks allot
thanks allot
thanks allot
thanks allot
Then why are you even asking? Just give Spoon (or insert some great Honda engine builder) a call and send a blank check. You will have exactly what you want then. A 1,200whp Honda can be made street legal and drive every weekend as well as the 70hp options readily available.
What are your exact goals/budget. Saying "max power" and streetability means nothing. If you want somebody to list a bunch of the most expensive parts - well you can do that research too.
H2b with decent amount of work .... and your not gonna wanna daily drive 300 whp in a Honda allmotor , it will get old fast , the only way I would say is j32 swap or k frankinstein would make The daily driving less painful
Me too - but with today's definition of "streetable", this could just mean it's "plateable"; or maybe able to be driven down the block and back. Some people even consider a weekend only vehicle streetable. To me it's something that could be driven every day and for long distances.
OP - You need to start researching H and K series engines if your goal is to truly stay N/A.
My favorite is when idiotic people say I want to be N/A - then ask how big of a "shot" can their engine handle.
Unless you look into some type of power adder for the power you want to be at, I hope you have as deep of pockets as you say you do.
Got a friend making 285 on a stock sleeves, stock crank and stock head cast with a High compression forged k24 block/ k20 head with drag cartel stage 4's and supporting mods. If budget isn't an issue obvious thing to go with is k-series. Ill post a rundown of his setup.
k24a4 block
87 mm supertech 13:2 pistons
H-beam rods
oem bearings clearenced
oem k20a oil pump nd baffle
k20a oilpan
k20a oil cooler
golden eagle head studs
oem head gasket
head .. prb-1 z1
full supertech dual vavle spings
Drag cartel stag 4's
stock vavles ..
xcessive intake mani ported runners 53 mm
q45 tb custom 4 inch intake with 4 inch v stack
hybrid header with full 3 inch mandrel bent exhaust.
http://www.youtube.com/watch?v=kFq5wuFVa5o
Made 35x and 3xxtrq on a 60 shot.
http://www.youtube.com/watch?v=Eg2DTYt9luY
Very Very streetable setup.
k24a4 block
H-beam rods
k20a oilpan
k20a oil cooler
oem head gasket
head .. prb-1 z1
stock vavles ..
actually it's my friends car and am trying my best with him to let him install a turbo but he doesn't want to for that i was asking here about the B16 because he's not planning to change it. and his targets is to beat some of the cars in the streets. thats it.
With a B16, he won't be beating anybody. Maybe a 3 cylinder GEO metro, but that's about it.
Harsh, but truthful lol. B16's aren't worth putting money into. The only thing worth keeping/building, is the head and putting it on an LS or B20 bottom end.
or turbocharging. that's why I kept my B16 spare engine. I can clean it up and make it a nice little turbo squirrel
Ive been dding my 250hp set up for 40,000 miles and it still getting faster so i wouldnt say it needs a rebuild every year . Hell im not even sure what it makes any more last time i had it on a dyno years ago it was 252hp and its on a h tranny not h2b so thats pretty good. But everybodys points are valid this thread is useless with out more info and a 250hp plus motor is going to cost you 5,000 and up no matter what motor you go with good luck with your build . Best budget build h2b ,shave the head to get the compression up and run pro 2s . 250hp can be made that way ,very streetable and as cheap as it can be done na.
seriously, 250-300hp is very very attainable on a stock b16 with a small to mid sized turbo. i tuned 3 stock block b16s last summer for some of my friends they are all great fun on the street. the only mods i would do to the engine are new oem hg with arp headstuds and upgrade to gsr cams. they are cheap and a very nice bump up from b16 cams which honestly suck,
if you want to go n/a for sure, it seems that people are making great power very reliably out of k series engines. im going to do that for my daily driver in the next few years
