CRX disc brake conversion trailing arm bushing issue
Old Feb 14, 2012 | 06:23 AM
dano670's Avatar
Default CRX disc brake conversion trailing arm bushing issue
Car is an 88 CRX and I believe the donor trailing arms are from a 91 Integra. Everything sems to be going well until I decide to install the CRXs trailing arm bushings in the Integra's trailing arms, because the donor car's were shot.
My digital calipers decided to break, but the best I can measure is the Crx original trailing arm bushings measure about 3 1/8" while the Intregra's measure about 3 7/16".
I went to two stores and both handed me the 3 1/8 bushings. I found that 95 and later Integra's have a different part #, but none of the stores locally have that part.
There was "3P" marking on the Integra's trailing arm.
At this point, I am wondering if I wasted money on a set of trailing arms or can I just transfer the parts over to the CRX trailing arms.
Here are pics of the trailing arms and bushings.
Old Feb 14, 2012 | 06:31 AM
dano670's Avatar
Default Re: CRX disc brake conversion trailing arm bushing issue
I may have solved the problem. After all the parts stores I went to, Rockautos catalog directs you to a Dorman part 905-751 with a larger diameter.
wickedEFguy
Jun 23, 2009 03:07 PM
crxnatic
11
Sep 3, 2008 04:29 PM
ED9man
21
Jun 7, 2006 05:07 PM
STN_Pat
Apr 9, 2005 03:09 PM
sleeperCRX
Sep 25, 2001 07:35 AM
