soft brake pedal. eg 5 lug
Old Feb 14, 2012 | 05:22 AM
mayfly's Avatar
Default soft brake pedal. eg 5 lug
car is a 1992 civic hatch with itr 5 lug
so i got into my car and started to drive and noticed my brake pedal was very very soft.
i e-brake'd it back to my driveway and turned the car off. i bled the system for air.
anytime i pump the pedal when the car is off the pedal gets hard within 2-3 pumps.
but if the car is turned on it just goes soft. any ideas? thanks H-T
Old Feb 14, 2012 | 05:31 AM
grumblemarc's Avatar
The Grumpiest
Default Re: soft brake pedal. eg 5 lug
Leaks? Check the lines, Master/slave for seepage. Air still trapped in system? Re-bleed. Brake systems are not that complicated so you should be able to track the problem down.
Old Feb 14, 2012 | 05:45 AM
mayfly's Avatar
ive re-bled about 4 times. but im not getting any air bubbles.
how would i check the master cylinder for seepage?
Old Feb 14, 2012 | 05:55 AM
The Grumpiest
Interior of the car. Look under the dash.
Old Feb 14, 2012 | 06:26 AM
mayfly's Avatar
ok will do when im off work. thanks
Old Feb 14, 2012 | 06:27 AM
Civic2Fast's Avatar
Check for vac leaks to the booster... I did a rear disc conversion on my eg and afterwards my brakes lasted about 3 weeks... I upgraded to a teggy non abs booster and master cylinder problem solved!!! oh and by the way my symptoms were as you described yours lol
Old Feb 14, 2012 | 06:29 AM
Civic2Fast's Avatar
if you have a soft pedal and you aren't losing fluid, definitely check your master cylinder and booster
Old Feb 14, 2012 | 06:32 AM
The Grumpiest
Booster! I meant booster and master cylinder (clutch on the brain). You know what I meant.
Old Feb 14, 2012 | 06:47 AM
Civic2Fast's Avatar
hahaha I picked up what you put down bud
Old Feb 14, 2012 | 09:16 AM
mayfly's Avatar
lol well thanks guys. much appreciated. ya i was wondering why the slave.lol
Old Feb 14, 2012 | 11:06 AM
98civdx's Avatar
Master Detailer
I am shocked no one asked, but did you install a 1'' MC?
Old Feb 14, 2012 | 11:32 AM
The Grumpiest
That's why you're here.
Old Feb 14, 2012 | 12:01 PM
mayfly's Avatar
yup once inch master and 40/40 prop valve and coated stainless steel brake lines
Old Feb 14, 2012 | 01:28 PM
98civdx's Avatar
Master Detailer
Start looking for leaks.
Did you bench bleed the MC?
kicken90crxsi
Suspension & Brakes
Jul 17, 2014 06:03 PM
crex23
Apr 30, 2012 07:40 AM
manichonda
Suspension & Brakes
Apr 12, 2012 03:57 PM
Scrapin4DR
Sep 9, 2009 09:27 PM
MyYellowHonda
Nov 22, 2002 04:24 AM
