94 Accord window regulator shot
Old Feb 14, 2012 | 04:12 AM
HankYee's Avatar
Default 94 Accord window regulator shot
Hi,
My driver side power window regulator is bad. The window is stuck open, is there
an easy way to shut the window, while im waiting for the new regulator?
Hank
Old Feb 14, 2012 | 05:55 AM
dglassmyer's Avatar
Default Re: 94 Accord window regulator shot
Had this same issue when mine went out, I just dealt with having a window down for a day or two.
I suppose you could pull the interior door panel, disconnect the window from the broken regulator and then prop it in the up position with something of suitable length, how easy that is for you is kinda relative.
Old Feb 14, 2012 | 08:42 AM
hondamark35's Avatar
i've had to do this fix a few times over the years. i've used scraps of wood, rigid foam, PVC pipe with notches... the key to making it secure is to lash the support to the frame of the door with some tape (duct or vinyl electrical tape work) so it won't shift around and drop the window while you're going down the road.
zroluv32
Oct 5, 2014 08:23 AM
dimo92
Mar 8, 2009 08:23 PM
silentdork818
13
Aug 7, 2006 11:36 PM
HatefulDjiN
May 23, 2006 03:14 PM
Milton90accord
Sep 5, 2003 09:00 AM
