any ITR owners ever changed piston before for higher comp...
I was reading hanes manuel and i need to use a rod strech bolt gauge
any suggestions
am interesting in changing the pistons for 13.1 compression will I have any valve to piston clerance problem.
I will probally get some eagle rods
current setup stock 2001 itr longblock with jun stage 3 cams
12.41 at 107mph
any suggestions
12.41 at 107mph
The stretch bolt gauge is available commercially at any specialise tool store. I had to get mine ordered in and it is $$$.
Also I do not know what you intend to do with the car but just in case a 13:1 CR for a daily driven car using pump gas will require some very accurate tuning.
what happens if I change the rods do I still have to use that tool lets say eagle rods with its own rod bolt I can just torque them insteadof using th estrech gauge????
thanks
thanks
"a 13:1 CR for a daily driven car using pump gas will require some very accurate tuning."
AND HOW!
AND HOW!
[QUOTE]I was reading hanes manuel and i need to use a rod strech bolt gauge
any suggestions
I think your reading the directions for your underwear
any suggestions
I have a friend who runs 12.7-8 on the street with no problems alltho he has a AEM EMS...
I thinks it all up to the tuning and the setup- so 13.0-13.5 might be a possiblity
DefiantGSR
Oct 28, 2008 12:50 PM
NSTY Z33
Aug 20, 2004 10:36 PM
