water in oilpan, not headgasket
Old Feb 13, 2012 | 01:08 PM
mhewitt's Avatar
Default water in oilpan, not headgasket
Just replaced a headgasket on lsvtec and had head straightened. Had driven around 50 miles and let idle for about hour and half. Then while driving in third gear full throttle a water hose busted, the one on back of block going from thermostat to back of head. Fixed that then oil light was on, checked oil n it was way overfilled.....strange. drained oil and all the water in radiator drained out of oil pan separately from oil. I poured more water in radiator (engine off) and it ran out of drain hole for oil. Would that be a cracked head? Or possibly sleeve? Just curious if anyone has had this problem.
Old Feb 13, 2012 | 05:23 PM
fcm's Avatar
fcm
Old Fart
Default Re: water in oilpan, not headgasket
Crack in head or block. 94
Old Feb 15, 2012 | 01:03 PM
Tim1982's Avatar
you may have pitched the head gasket and may need to replace it again. Or the block or head is cracked.
Old Feb 15, 2012 | 02:07 PM
hybridmiklo's Avatar
block test it
Justin Branham
Feb 22, 2019 09:06 PM
Flatland2D
Jul 15, 2010 12:54 PM
pjg
Mar 8, 2010 03:50 PM
y2kferari
May 3, 2009 11:05 PM
caminSi
Jul 27, 2006 07:52 AM
