CEL Light ON
Old Feb 13, 2012 | 10:31 AM
9tailsfox's Avatar
Default CEL Light ON
Well. I know if the CEL light on. We need to check tool to get the code know the problem. Before I go to mechanic check. If my civic 1994 high rev about 5500 rpm then the check engine light on after that when I stop the car somewhere traffic light. My Idle seems little high about 1600 rpm with the check light on. after the I off and on the engine it gone an back to normal idle. So any one know this symptom? Some say is Map sensor....
thank you
Old Feb 13, 2012 | 10:32 AM
grumblemarc's Avatar
The Grumpiest
Default Re: CEL Light ON
Sticky: How To Retrieve Check Engine Light (CEL) Codes/List of OBD1 CEL Codes
Old Feb 13, 2012 | 10:39 AM
sfar785's Avatar
well if he's obd2 then he needs the code reader, can't tell us anything until he goes and checks it.
Old Feb 13, 2012 | 10:44 AM
The Grumpiest
What? I can get my wife to pull codes using the paperclip trick on her 97 hatch. You don't need a code reader.
Old Feb 13, 2012 | 10:47 AM
Civic2Fast's Avatar
Love it!! Universal code retrieval tool!!
Old Feb 13, 2012 | 10:48 AM
sfar785's Avatar
hahaha, as wrong as i was that was still pretty LOL worthy. I dunno, never had anyone tell me they used the paperclip on obd2 cars, always had readers.
Old Feb 13, 2012 | 06:35 PM
9tailsfox's Avatar
Hi... This puss is lovable when help in needed. One question before I put the pin to the jumper plug. This is easy that I found 2 cable there. But as my passenger seat is on the left (and Mine is original JDM EG9). I found that one cable that got three hole plug and another one is two hole plug. According the web said that EK two hole plug is blue with brown and black wire while EG is Gray with tan and green wire. But Mine is blue plug with brown and black wire. My all harness never convert to EK OBD2. Mine is still OBD1 so is that ok to plug since is the only cable that I found. Haha I scare that short my ECU.
just after an hour I just tried the paper clip to the blue plug. The CEL flash 7 times 0.5s. So I assume is Code 7. According the code is the TPS sensor. Hmm... Once I did replace the TB. But not change the whole TB with sensor. Put back the sensor in place just change the TB 62mm. Could it be the TPS need to be calibrate or a faulty TPS? Thank you
Old Feb 13, 2012 | 10:47 PM
sfar785's Avatar
gonna have to adjust the TPS
Old Feb 13, 2012 | 11:10 PM
9tailsfox's Avatar
Yeah I think need to recalibrate the sensor. But the matter is it need to back probe the middle sensor cable to 0.45 v with using a vol meter. But I'm lazy to do that... Ahw... I need some solution that not require tools and skill like the question title above that got the answer. Thanks Puss Once again meow.... oh yeah puss do you wear boots? any solution that just need some degree to adjust the TPS without vol meter? Thanks
Old Feb 14, 2012 | 01:37 AM
HondaPartsHero's Avatar
Technical Hero
No you have to use a meter
https://honda-tech.com/forums/tech-misc-15/diy-how-calibrating-voltage-your-tps-sensor-2947986/
Old Feb 14, 2012 | 08:24 AM
9tailsfox's Avatar
Ok finally I use a needle to reach the middle sensor cable. I wonder how they can use a paper clip? doesn't matter... The reading from my volt meter v1.57 and this is the minimum that I can adjusted by Closed Throttle. If maximum will around 1.85. So is this the sensor is faulty closed throttle? v5.07 Wide Open Throttle(WOT). If do I won't waste much time for tuning it. Thank you.
If just measure the voltage cable only.(not the middle cable) is v5.07.
Old Feb 17, 2012 | 09:43 AM
9tailsfox's Avatar
hi, Well I just replace an used part TPS sensor from a d16a and I did success adjust it V0.45 CT and V4.50 WOT. But the matter is the idle is erratic up and down. So is it the D series TPS is compatible to b-series? any idea?
(Well the previous TPS is v1.85 CT and v5.07 WOT. but the idle is ok the matter only check light when hit some high rpm)
Old Feb 18, 2012 | 02:24 AM
9tailsfox's Avatar
hello, I set my TPS v0.26 Closed Throttle and v4.5 wide open throttle is that ok? Because when I set CT to v0.45 the rpm rev like hell 2500-3000. Is it as long as the WOT is v4.5 while my CT v0.26 idle rpm 700-800 and that should be fine right? thank you
Old Feb 20, 2012 | 07:39 AM
9tailsfox's Avatar
no 1 answer me IOI
Old Feb 20, 2012 | 07:44 AM
The Grumpiest
Does the car drive well?
scubacamper
Aug 30, 2015 01:06 PM
patpeery
Apr 4, 2008 02:40 PM
haynesbc
Mar 2, 2008 12:22 PM
JDM-EJ1
Apr 5, 2005 11:55 AM
97gSrkId88
Mar 20, 2003 11:06 PM
