Good Oil vs. Cheap Oil
Hi my 91' Accord with 173,000 miles looses oil pressure when engine is hot. Im using cheap parts plus oil right now. Would it be worth it to use amsoil or a better brand like that.
Does the better brands hold viscosity with heat?
Some high mileage oils will leak less, but if it's not leaking, the type of oil won't matter. Are you sure you're not burning it? Any odd smoke from the exhaust or under the hood?
Provided your oil is the correct weight (5w30 IIRC) and you have the correct sized filter (M104 if Mobil 1) then you should be ok on those items.
Are you seeing a Check Engine Light (CEL) ? When you 'lose pressure' or how are you identifying/verifying that's the issue.
Well when I was running just 5w30 I had maybe 3psi, but when I added the gunk oil treatment it raised it to about 8psi.
Heres my psi readings:
Cold Start Up: 80-90psi
Warm idle: 25psi
Hot Idle: 8psi
With the oil treatment it raised the viscosity to 10w40
The gauge im using says:
Engineered as Class B (3-2-3)
0% - 25% span = 3% accuracy
25% - 75% span = 2% accuracy
75% - 100% span = 3% accuracy
Warm idle: 25psi
Hot Idle: 8psi
the guide line that I was told is you want 10psi for every 1,000rpm, so if you are stock idle speed ~750-850rpm then even 8psi is ok. Is sounds like you may have a worn oil pump or worn bearings that are allowing the pressure to drop.
Also oils are all pretty much the same regardless of brand, as long as they are ASE, API, and ILSAC rated. If you want you can try running a thicker weight oil because these oil will create more pressure flowing through looser clearances.
EG-SIXV-TEC
11
Dec 13, 2012 02:45 PM
Nextelbuddy
Mar 6, 2004 01:36 PM
itr501
Oct 23, 2001 02:41 PM
