B18c White Smoke
Old Feb 13, 2012 | 08:58 AM
trojan's Avatar
Default B18c White Smoke
hi guys...i own a b18c..and when vtec is kickin in white smoke appears to come out of the exhaust...i m using Torco SR1 Fully Syntetic Oil 10 40w.... what do you think about the white smoke pls? any suggestions what should i do?
Thanks
Old Feb 13, 2012 | 09:03 AM
Cap'N Chronic's Avatar
Default Re: B18c White Smoke
It's most likely a bad head gasket or bad rings.
Old Feb 13, 2012 | 09:05 AM
Not sure if it could be due to the increased weight of your oil, since your running a heavier weight than Honda recommends. I really have no idea about that though, maybe someone else could clarify?
Old Feb 13, 2012 | 10:14 AM
cvcrcr99's Avatar
White smoke = coolant/water.
I sould suggest to do a compression test on the motor and check for coolant mixing with oil first.
Old Feb 13, 2012 | 10:15 AM
sfar785's Avatar
it's a head gasket, now follow this up with 40 other posts confirming it's a head gasket. Do a compression test and tell us your numbers.
Old Feb 13, 2012 | 11:23 AM
Korean99EK's Avatar
like everyone else said go with a compresson test and lets us know what your numbers are. and yes its prob going to be your head gasket.
Old Feb 14, 2012 | 11:18 AM
trojan's Avatar
thanks for now guys...will let you know about it! thanks again
Old Feb 26, 2012 | 11:22 AM
trojan's Avatar
hey guys...can you tell me what number should i ll be reading for the compression test to be good? coz this wk i am going to make it.thanks
Old Feb 26, 2012 | 02:18 PM
Kohen's Avatar
Just come back with the numbers. We'll let you know.
alswizzo
Jan 24, 2013 05:27 PM
Redprelude98
Nov 25, 2008 10:42 AM
chu77
May 25, 2006 07:55 AM
vtec4u92
Apr 1, 2006 12:15 AM
All Motor EG
Jul 22, 2002 09:48 AM
