93 dx d16z6 tps map sensor issues
Old Feb 13, 2012 | 08:34 AM
ej1b18c1's Avatar
Icon2 93 dx d16z6 tps map sensor issues
car is a 93 civic dx hatchback manual
engine is a d16z6 using d16z6 engine harness and 5spd p28
everything starts and works after swapping engine but getting cels for code 3 and 7 (map and tps) prior swapping the d16z6 engine out of the other car it had 0 cel/check engine light. 02 sensor and vtec is wired correctly etc. ive checked to see if i got the tps and map plugs switched but seems to be right. Question is, how do i check the wiring from the plugs to the ecu to make sure they are in the correct place to the ecu. prior the hatch had a gsr in it. the sensors should be working because they were fine before the swap and are not damaged. please help!
Old Feb 13, 2012 | 11:16 AM
ej1b18c1's Avatar
Default Re: 93 dx d16z6 tps map sensor issues
anyone have a suggestion of what i can do to figure this out?
Old Feb 13, 2012 | 04:49 PM
ej1b18c1's Avatar
ttt
Old Feb 13, 2012 | 05:04 PM
94EG8's Avatar
Seagull Management
Which MAP plug did you use? You need to use the one going to the firewall mounted MAP sensor, simply unplug it and plug it into the MAP on the top of the throttlebody.
Old Feb 13, 2012 | 05:20 PM
ej1b18c1's Avatar
im using the map sensor plug off of the d16z6 harness. i dont see any firewall map sensor plug. the swap, harness everything COMPLETE is out of a running 94 civic ex with no cels.
Old Feb 13, 2012 | 05:30 PM
94EG8's Avatar
Seagull Management
Unless you used the cabin harness from the EX too the MAP sensor plug on the engine harness goes to nowhere. It stops at the shock tower plugs, the wiring isn't there on the other side of the plug.
'92 - '93 DX/LX models only (as well as CXs and EXs sold in Canada) have the firewall plug as part of seperate harness that runs straight from the ECU through the firewall to a Firewall mounted MAP sensor that's bolted to the fuel filter bracket.
Old Feb 13, 2012 | 07:26 PM
ej1b18c1's Avatar
Icon6 Re: 93 dx d16z6 tps map sensor issues
that's funny because both model cars are canada models but i know for a fact my ej1 map is NOT on the firewall probably because its a 94. Maybe on the hatch was on the firewall prior to it having the gsr swap but its non existing at this point.
i will test continuity from the tps/map sensor plugs to the shock tower and test it to the ecu plugs and see what i have. so your saying i may have to hard wire the map sensor since it the.harness shouldve been mounted on the firewall from factory? weird because when the gsr was in there it was running good with no cel besides the vss.
Old Feb 13, 2012 | 08:23 PM
94EG8's Avatar
Seagull Management
Remember, made in Canada does not equate to sold in Canada. Most '92 - '95 hatchbacks were built in Alliston Ontario Canada, regardless of whether they were made for the US or Canada. But they were built to different specs. Our CX came with a D15B7 unlike the US models that came with the D15B8 8 valve boat anchor. Basically what it comes down to is '92 - '93 Civics that came with a D15B7 had a firewall mounted MAP, all others had a MAP sensor mounted on the throttlebody.
Yes do that, and yes the original MAP sesnor was mounted the firewall as shown in this pic:
I really have no explanation for that.
Old Feb 13, 2012 | 08:34 PM
Former User's Avatar
You could just check which MAP plug gets 5 reference volts from the ECU with the key in ON(II). Do the same for the TPS plug.
Old Feb 13, 2012 | 09:24 PM
ej1b18c1's Avatar
94eg8--RonJ@HT-----
I understand the firewall map senor and I think I've seen it before, it defenintly does not have the firewall map sensor plug. IDK where the heck it's at, probably the previous owner ripped it out or something. I will test the only map sensor plug I have from the d16z6 engine harness and see what it reads, same with the tps in the morning. It's the middle wire that's supposed to read at 5v?
Old Feb 14, 2012 | 06:45 AM
Civic2Fast's Avatar
94eg8--RonJ@HT-----
Yes... just take you multimeter and ground straight to the battery... remember though, with the TPS plugged in you should get around .5 volts and 4.5 to 5 at WOT (wide open throttle)
Old Feb 14, 2012 | 08:49 AM
ej1b18c1's Avatar
ok will do, will post with updates later. thanks for all the help everyone.
Old Feb 14, 2012 | 01:33 PM
ej1b18c1's Avatar
Okay, I tested continuity from the tps/map plugs to the ecu and all are connected as followed from left to right as if you were plugging it in:
MAP= Left wire (yel/red) to ecu (yel/grn) D19 VCC1 sensor voltage for Map (reads at 0.00)
Middle wire (grn/white) to ecu (blu/grn) D21 sensor ground (reads at 0.00)
Right wire (wht) to ecu (pnk/wht) D17 Map sensor (reads at 0.00)
TPS= Left wire (grn/wht) to ecu (grn/wht) D22 SG2 sensor ground (reads at 0.01)
Middle wire (red/blu) to ecu (pnk/blk) D11 TPS (reads at 0.00)
Right wire (yel/wht) to ecu (yel/wht) D20 VCC2 sensor voltage for TPS (reads at 4.89)
Does the wiring seem right? When I tested each wire I put the key on and grounded the other and that's what it read. I'm not sure if I'm doing this right or not. LMK what you guys think and suggest. Thanks
Old Feb 14, 2012 | 03:04 PM
Civic2Fast's Avatar
Are you doing this with the plugs connected???
Old Feb 14, 2012 | 06:25 PM
ej1b18c1's Avatar
Civic2fast---- No I dont think I'm doing it right. How do I test it with the plugs connected? From the ecu?
Old Feb 15, 2012 | 08:02 AM
ej1b18c1's Avatar
ttt
Old Feb 15, 2012 | 03:22 PM
ej1b18c1's Avatar
??? Well can anyone else lmk how to properly test the map/tps? I am trying to get this car running with no cel asap. Also can an intake manifold/tb vacuum leak cause these codes to come up?
Also is my wiring from my plugs to the ecu correct? Thanks
Old Feb 17, 2012 | 07:56 AM
ej1b18c1's Avatar
***update***
I got a known working d16z6 throttle body with map/tps sensors for $30 with tb gasket. I also replaced all vacuum lines and made sure they were in correct order. After resetting the ecu I cranked the car over and starts right away but CEL jumps on right away. So I check the cel and it's just code 3 for map sensor. At least the code 7 tps sensor went away.
So I check the map plug (while connected key in II position)and here's what came out:
Left wire (yel/red)=4.89 D19
Middle wire (grn/wht)=0.01 D21
Right wire (wht)=0.09 D17
Old Feb 17, 2012 | 09:12 AM
The Wht wire should also have 5 reference volts. Check the Wht wire for a short or open between the ECU and MAP sensor plug.
Old Feb 17, 2012 | 10:01 AM
ej1b18c1's Avatar
i also changed the im gasket and still no luck. the rpm fluctuates up and down between 1300-1700rpms. i will see if i can find a short, idk
it has continuity from the plug to the ecu, trying to find a short. when testing what voltage on the volt meter what should i be using? like 12v, 9v, 6v, 1.5v im getting different readings on each setting.
Old Feb 17, 2012 | 11:22 AM
ej1b18c1's Avatar
all the wiring seems to be fine, idk whatelse to do. When the car is running the idlw lopes and when i unplug the plug from the map sensor idle does not change at all. will the evap sensor, iacv, iat having anything to do with this? when the engine was in the other car it was running fine with no cels! does my wiring seem to be going to the right pins from the map to ecu?
please help! i dont know what else to do
Old Feb 17, 2012 | 11:25 AM
Are you ignoring the fact the Wht wire should have 5V but doesn't? Did you test the Wht wire for a short or open?
Old Feb 17, 2012 | 11:55 AM
ej1b18c1's Avatar
on my volt meter what voltage should i test it with? 12v, 9v, 6v, or 1.5v ?? i get different readings on each. just run the wire back and check for any breaks etc?
Old Feb 17, 2012 | 11:59 AM
Use the 6V scale.
Are you using a digital multimeter? You should be as an analog voltmeter could damage the ECU.
If you verify lack of voltage, then test the wire near the ECU where the voltage comes from. Do you measure about 5V there?
Old Feb 17, 2012 | 12:50 PM
ej1b18c1's Avatar
im using a digital multimeter.
used the 6v scale and can only get a reading of 0.04 at the ecu.
