93 dx d16z6 tps map sensor issues
#26
#27
Re: 93 dx d16z6 tps map sensor issues
the ecu is all plugged in with key in II. Weird because the ecu worked perfect before with no issues. IDK I'm stumped and would hate to buy another ecu and still have the same problem.
#28
#29
So I took the wht wire out of the plug and swap another wire in there straight to the ecu, tested it and was the same result of 0.04. Did this just to eliminate any kind of shorts etc in the new wire but no luck so after I was done I just put it back how it was. So with this said the ecu must be gone?
#30
Seagull Management
Pull the cover off the the ECU and look for anything burnt. If you get certain plugs backwards you can burn certain components, but normally the ECU is repairable.
#31
It seems driveable but don't want to sell it like that.
#35
Okay, I will try it out and see what happens. I always thought when an ecu is bad it has a solid cel on with no error codes.
#37
**update**
I put the p28 in my gsr ej1 and zero CEL's. So it can't be the ecu. When the p28 is in the hatch the cel comes on as soon as I start the car, as if the plug is not even connected to the map sensor. I have no idea at this point, and must be wiring but all show continuity from the plug to the ecu. I've tried other map sensors as well and not sure what's going on so any suggestions will help a ton!
94EG8***** THANKS!!! You saved me $80 for your bright idea.
#38
**update**
#39
Seagull Management
glad to help
Generally speaking when the ECU was fine before the swap and it mysteriously appears bad I'm very hesitant to replace it even when the flowchart seems to point to it.
#40
I guess I have to check all the wiring. I know each wire on the map plug has continuity to ecu so there's gotta be a short somewhere. I could just hard wire all three wires to the ecu and see if that works, even though it will take time but so is tracing all the wires back to the ecu.
note* It's not like the cel comes on during driving, it's right away like it's not plugged in and nothing changes when plug is not connected so it's gotta be a short somewhere. Wire hunting in the morning, thanks for all the help much appreciated
#41
#42
Typically, with most MAP sensors, there is a 5 volt supply wire and a 0 volt supply wire, which, theoretically is at the same potential as chassis ground, but due to real world electrical loads on the chassis, this can vary, which is why it is separated from those electrical loads. The MAP sensor is a rather elaborate electronic potentiometer that varies the output voltage from 0 to 5 volts based on pressure/vacuum imposed upon the stress gauge device within the sensor. If you had 5 volts at both input wires, there would be nothing to reference between. That said, one wire should be 5 volts, and one should be 0 volts, and the 3rd output wire should vary between these two voltages depending on vacuum. Also, all voltages read from the 3rd 'output' wire should be referenced to the 0 volt wire, and not the chassis, as this will isolate readings from voltage drop and changes on the chassis ground when things are turned on like headlights.
#43
#44
after looking everywhere im stumped. been tracing wires and everything looks good. have tested continuity from plug to shock tower from shock tower to ecu and even plug straight to the ecu. i cant find a short anywhere. having a hard time thinking its the ecu when i tested out on my other car and it had no cels what so ever. i will keep looking.
#45
If the Wht wire has continuity and no short from the ECU to MAP sensor and voltage still does not reach the MAP sensor plug, then the ECU must be bad.
This assumes that you are doing the electrical tests correctly.
#46
using 6v scale while all plugs in key on position II testing it from ecu
wht reads 0.04
grn\wht reads 0.01
red/yel reads 4.89
i even swapped the wire with new one straight to ecu and still reads 0.04.
but why would no codes/cel come up while using the same ecu in my other car if it it was bad?
#48
#49
You might try this:
Unplug ECU connector D and turn the key from off to ON(II). Measure voltage between D17 (+) and D21 (-) from the ECU, not from ECU connector D. Do you now measure 5V?
When you did the original MAP sensor plug tests, did you measure voltage at the Wht wire terminal using the Grn/Wht wire terminal as ground?
#50
You might try this:
i was using the body ground or neg side of battery
