Jeep Cherokee Limited TeraFlex Procomp Lift F/s F/t
Jeep has 149,000 miles...Runs, Drives, Brakes..Lights and Gauges work.Leather interior is there..not a trailer queen..Clean title in hand..In no huge rush..just testing the waters..Been real busy lately..trades are welcome....
Has a few things done to it.....
4.5 inch custom lift..with 30" tires...50-60% tread on Pro comp rims 15x9
TeraFlex Rear Disc Brake Conversion...Zj master cylinder and brake booster..
HD springs
Tubular control arms...upper/ lower
Teraflex shocks
Front bash guard with tow hooks and stinger
Rear bash guard with tow hitch
Zj v8 steering conversion..brand new..
Rubicon Xpress steering stabilizer
3 inch drop pit arm
Crown stainless brake lines
full exhaust...have extra manifold and down pipe
Solid engine mounts.....american made
Ruff Country track bar with 3 inch drop...poly bushings
cold air intake
maintenance done over the past 15k miles or so...
Oil change every 3k
Tune up with plugs and wires...newer cap and rotor
Newer starter and alternator..Napa...still under waranty
Gates power steering pressure hose
Fel-pro blue oil pan gasket
Water pump...Napa
Moog ball joints...upper and lower
Front wheel hub assembly's....both sides....Napa
Fuel pump...Napa
Fel-pro Diff.. seals.....front and back....replaced with Valvoline fluid
Front calipers...rotors...pads
im sure that i forgot a few things.........
***have extra trans and transfer case, extra spare parts i haven't installed yet...ect..***
Cons...
no a/c ...heat works
has dents and scratches....body is not perfect
windshield has small crack
paint is faded in some spots
seats are worn
$2800.00 FIRM
Text anytime...no calls after 9 pm....630 885 2213..thanks
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
HD springs
Teraflex shocks
3 inch drop pit arm
cold air intake
Oil change every 3k
Water pump...Napa
Fuel pump...Napa
Cons...
seats are worn
$2800.00 FIRM
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]
xSteve_Ox
Suspension & Brakes
21
Jul 11, 2014 04:14 AM
